61-80
81-100
101-120
121-138
"Maybe input this on the Dimension Menu will be very fine! ;)"
YES!!! it would be amazing!
Changed line 135
textframe.origin = frame.evaluate(textShift, (1-2*(angle>=180))*(lineWidth+textSize/1)/2, 0);
The distance from the dimension line has increased.
BUT! The angles are displayed incorrectly.
Hi
Will the script work on Mac - and how?
Hi Karl, yes the dimension script will work on the Mac version as well.
You can download the latest version of the script from Max's site here:
http://moi.maxsm.net/media/files/ the one you want is named Dimensions.v.1.0.2015.09.14.zip
Then for installation instructions please refer to
FAQ #1, how do I install a plug-in script? .
Hi All,
I have read this thread with some interest as it may be feasible for me to somehow export MoI3D files with dimensions. I also noticed that Michael had/have this as a potential part of a V4 release ...
To this end: Is there any news on whether or not this will be part of a V4 release - and if so when is the V4 release due?
Have a good day ;-)
Jesper
Hi Jesper, I can't really promise 100% that it will be in v4 but it is one of the priorities that I want to work on. I won't really know how it will go though until I've been able to work on it some.
The V4 beta test period just started a few weeks ago, and could last anywhere between 4 to 9 months before the v4 final version is ready.
Right now the only things I can say for sure that will be in v4 are that it will be 64-bit and have a native Mac version.
Seems Dimension by Max Smirnov works also with the Beta of the 27 November 2017!
Hello,
It dosn“t work with V4 beta (18.11.). Invalid function argument 1 , line 1
Only for me?
Hi Michael - as always thanks for your prompt and helpful reply ;-) ... I will look out for what happens with the v4 as it progresses ... Have a good weekend when you get to that ... Jesper
HI
I also have a problem when :
1 - i call this fonction (TypeError...)
2 - i select an objet and call this fonction (Invalid index ...)
3 - i would like th draw a dimension ( tab is empty , color line is white)
chri
Hi
A dumb question.
Is there a way to get Max's dimensions to display feet/inches/fractions?
thanks,
eric
hi eric
Please take a look to the previous post 7403.93
chri
Dimensions v1.1
Improved compatibility with MoI v4
Added font change menu
http://moi.maxsm.net/item/37
Great !
Thanks a lot Max
Thank you so much, this script is too useful ..
Thank you very much Max!
Great job...as usual :)
Hi
Thanks a lot Max
Christian
French Version! ;)
http://moiscript.weebly.com/cotations.html
61-80
81-100
101-120
121-138
