48-67
68-87
88-107
108-127
128-138
Yes. Missed one Round call. Fixed and uploaded.
""""""""So my version will be customized with funny thing max="14" (line 282) """""""""""""""
Mine is set to "15" and outputs 15....
I also set my default at 4 and wrote in to default with "units" checked and also to have "in" as the trailer.......
you right 15 seems the ultime limit :)
wow. that script is phantastic. thanks a lot!
that really will save me a lot of time.
the script is not working for me. I got the script error. The language is Finnish.
Hi JL82,
From the error it looks like you are running MoI version 2, and I think the script requires MoI version 3 in order to run properly.
Yes, I have version 2.
Hello everybody.
The distance, the red arrow can be changed? Between the dimension line and digits?
Through editing files "_Dimensions.htm" or "_Dimensions.js"?
I am affraid not yet but just select and move it! ;)
Hi GonzoRus,
Yes it's possible to change that spacing by editing the _Dimensions.htm file.
Using the latest version Dimensions.v.1.0.2015.09.14.zip which you can get from here:
http://moi.maxsm.net/media/files/ , you would want to modify line #135 which sets the placement of the text.
135: textframe.origin = frame.evaluate(textShift, (1-2*(angle>=180))*(lineWidth+textSize/3)/2, 0);
You would want to add something to the 2nd parameter to frame.evaluate(), like this for example (see the bold text for the + 1 that is added):
+ 1, 0);
Cool ! Will be added to the manual!
Done!
http://moiscript.weebly.com/cotations.html :)
Hi guys :)
This +1 method doesn't work correct in some cases.
It will be better to use the following line:
textframe.origin = frame.evaluate(textShift, (1-2*(angle>=180))*(lineWidth+textSize/2)/2, 0);
or
textframe.origin = frame.evaluate(textShift, (1-2*(angle>=180))*(lineWidth+textSize/1)/2, 0);
or
textframe.origin = frame.evaluate(textShift, (1-2*(angle>=180))*(lineWidth+textSize*3)/2, 0);
Maybe input this on the Dimension Menu will be very fine! ;)
"Maybe input this on the Dimension Menu will be very fine! ;)"
YES!!! it would be amazing!
Changed line 135
The distance from the dimension line has increased.
BUT! The angles are displayed incorrectly.
Hi
Will the script work on Mac - and how?
Hi Karl, yes the dimension script will work on the Mac version as well.
You can download the latest version of the script from Max's site here:
http://moi.maxsm.net/media/files/ the one you want is named Dimensions.v.1.0.2015.09.14.zip
Then for installation instructions please refer to
FAQ #1, how do I install a plug-in script? .
Hi All,
I have read this thread with some interest as it may be feasible for me to somehow export MoI3D files with dimensions. I also noticed that Michael had/have this as a potential part of a V4 release ...
To this end: Is there any news on whether or not this will be part of a V4 release - and if so when is the V4 release due?
Have a good day ;-)
Jesper
Hi Jesper, I can't really promise 100% that it will be in v4 but it is one of the priorities that I want to work on. I won't really know how it will go though until I've been able to work on it some.
The V4 beta test period just started a few weeks ago, and could last anywhere between 4 to 9 months before the v4 final version is ready.
Right now the only things I can say for sure that will be in v4 are that it will be 64-bit and have a native Mac version.
Seems Dimension by Max Smirnov works also with the Beta of the 27 November 2017!
48-67
68-87
88-107
108-127
128-138
