126-145
146-165
166-185
186-205
206-225
226-245
246-265
566-575
Hi Moritz, yes in V4 I do want to improve the FBX exporter to include object names and material assignments.
For now if you use .obj format instead for going into Keyshot, those will come through.
Hi Michael, thanks for the quick reply. I'm already looking forward to the new version. That will definitely be a bang
- moritz
Hi Moritz, just to clarify - that's something I want to improve during the v4 beta period. I don't expect to have that done for the very first v4 beta release though.
Also adding to this wish list would it be possible when exporting a part from a multi part object or just selected object that the file name picks up from the selection this would make a very handy feature in handling assemblies and say exporting out separate STEP files for manufacture and not manually naming a part the wrong name.
Look forward to new release.
Message 6925.190 was deleted
At last~! The Moi3d GUI is now - PERFECT in all its glory:
Nevertheless - would like an OPTION CHECKBOX where, if I choose, the folders will ALL REMAIN OPEN instead of 'one-at-a-time' -
Included are the LIGHTING OPTIONS & every custom script~!
Hi Ced,
They will remain open if you have enough vertical space available to show them all at the same time. You'll only get the "one at a time" type behavior if your monitor is not tall enough to display them without showing a scroll bar.
The down side to the arrangement you have set up there is that just the titles of the palettes are now taking up more vertical space than if you had some combined like in the regular default interface. With the default interface you'd be more likely to be able to have maybe 2 stay open at a time.
Hi Alex,
It could be possible to make a script to do this in v3. The only complication is determining which directory to use for the file.
That would be great - what about just exporting to the directory the parent file is in. Would it be possible if you had a large assembly with multiple objects selected to be exported as seperate files in their respective names?
thanks again.
Hi Alex, could you give some more detail on what you mean by the parent file? Do you mean something like a STEP file that you imported into MoI (which would be difficult since that filename is not stored anywhere currently), or do you mean a 3DM file that you have opened?
Do you mean you would want the file export dialog to pop up for every named object with that name as the default, or do you mean it would just do the export without bringing up any file dialogs at all?
Here is a typical file that I work with an Assembly which I used to build in SOLIDWORKS and now I put these together in MOI in much quicker time design and part creation. The parts contained get output as STEPs. The tube work goes to tube laser cutters and they use STP and the sheetmetal goes to the sheetmetal guys and they use STP also.
I currently export out each part individually and name as I go. I usually create a PARTs folder in the same folder that the master assembly 3dm file sits in. From there I email the supplier the parts they require. I also use the cutlist script to create a BOM Bill of Materials but I guess as you get closer to V4 and file instances become possible It maybe better handled then to get a list of files contained and how many times they have been used. Currently the CUTLIST script does OK job but sometimes gets confused with duplicate same name parts.
MOI maybe small and nimble but it packs a punch in CAD arena I work with other SOLIDWORKS guys and they cant work how I detail projects so quickly and have to say its due to MOI - I can conceptualise and problem solve at a very fast rate.
Many thanks
Alex.
SAMPLE ASSEMBLY.3dm
Wish list: Tool Tips!
sidePaneToolTipCode.zip
Michael,
Just a request to KEEP the export to SketchUp you currently have. It's a life saver and pretty much impossible to duplicates without extreme effort if importing the same OBJ into SU.
I'm working on several VR workshop gigs as well as working with China on a Design and Innovation Center where I will be teaching much of the VR pipeline I'm currently building. MoI is a key part of it as it's super NURBS -> SU is a key component and would hate to lose it in case you were thinking it's outdated. Thanks for putting it in!
or keep name for have different versions of SU Export! ;)
Export_SU8 (?) (I don't remember exactly what was the last format of Su export by Michael !
export_SU2015
etc...in general have a low version is better for a more large audience! ;)
SU V6 format is enough for quasi all things! ;)
Hi Alex, please try the attached script for your named file exports. Instructions for installing a plug-in command script
here.
To use it, select your named objects then run that command. It will write out a separate .stp file for each group of named objects.
Hope that's what you were looking for!
ExportNamedObjects.js
Hi Chipp, I'm glad the SketchUp exporter is useful for you!
MoI v4 will still have it, using an updated .skp library that will write SketchUp 2016 .skp files now I think. There's also a change so that each MoI object will be written as a separate group object in SketchUp so that 2 objects touching each other won't merge vertices together as will happen currently. You'll be able to turn it back to not making groups too if you want.
I was able to get updated libraries for all import/export formats that MoI uses so none will be missing for v4.
@Chipp despite the description of Michael in case of transformation of the actual SU format don't work for you...
you have a very simple solution : keep the V3 Moi3D in a corner of your computer! :)
That's right Frenchy, mine's sitting over there next to the pop machine.
HI Michael,
Great script it works very well just added another arrow to the MOI toolkit.
Thanks again for the custom tailoring of solutions to improve workflows.
All the best
Alex.
Thanks, Michael. Sounds great and look forward to testing it out! Yes, Monsieur Pilou, I will be also keeping MoIV3 :-)
126-145
146-165
166-185
186-205
206-225
226-245
246-265
566-575
