Full Version: Polygonal Converter.
Show messages:  1-5  …  406-425  426-445  446-465  466-483
31 Oct 2016   [#466] In reply to [#465]
Hi gara, over here I'm not able to reproduce any problem using a cube drawn in MoI.
What error message are you seeing?
31 Oct 2016   [#467]
I don't know if I attach the image in the right way, but the error is this
http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=140a23dbbe6dcd26987b7844d598d45e&filename=Immagine.jpg
Message 6674.468 was deleted
31 Oct 2016   [#469] In reply to [#467]
Hi gara, are you possibly running an older version of the script? Try getting the latest one named Subdiv_beta9.zip from here: http://moi.maxsm.net/media/files/ .
Also what version of MoI are you running it with?
1 Nov 2016   [#470] In reply to [#469]
With this new version works perfectly.
There is a way to check the tangency and curvature?
1 Nov 2016   [#471] In reply to [#470]
Hi gara, MoI does not really have any tangency or curvature analysis tools currently, it's not a focus area for MoI.
But if you turn on metallic lighting and set some specular highlights on under Options > View > "Lighting options", you can look at the reflective highlights to see any major breaks.
1 Nov 2016   [#472] In reply to [#471]
Ok, thank you Michael!
1 Nov 2016   [#473] In reply to [#470]
The CCC script shows some curvature lines and radii, for curves.
1 Nov 2016   [#474] In reply to [#473]
Thanks bemfarmer, but this plugin does not work with the subdivision surface
2 Nov 2016   [#475] In reply to [#474]
CCC will work for curves obtained from a surface.
The curve can be an isocurve from a surface, or a curve copied from an edge.
2 Nov 2016   [#476] In reply to [#475]
Hi Brian, one thing to be careful about is a curve on a surface can have very different curvature properties than the surface itself.
Like for example, here's a planar surface that has curvy isoparms and edges:
19 Aug 2017   [#477]
I just successfully converted a retopologized ZBrush mesh to a solid thanks to ImportObj and Subdiv. Brilliant work, Max, many thanks!
Any chance of continued Subdiv development, like triangle subdivision optimization? It would be fantastic if you could make a smoothly subdivided solid from a triangulated, decimated mesh, like the output of Zbrush Decimation Master or Blender's Decimate modifier.
Thanks again,
19 Aug 2017   [#478]
P.S.: A tip: if your mesh is fully symmetrical, import and subdivide half the mesh into MoI, then mirror and join to a solid. It will save quite some calculation time, and enable you to import larger meshes with more polygons.
Message 6674.479 was deleted
1 Mar 2018   [#480]
Not essential but...
does it possible to have "Snap" when move segment during the SSplit ?
13 Jul 2018   [#481]
Hi I cannot get this script to run for the life of me I'm on windows 10 is there something I missing on the install? Goes into commands right for the SubDivbeta9?
13 Jul 2018   [#482] In reply to [#481]
Hi Dave, there are some instructions on how to install plug-ins here:
http://moi3d.com/faq#Q:_How_do_I_install_a_plug-in_script.3F
Some things to look out for - make sure you have unzipped it, you need to copy the contents of the .zip file into the commands folder, not the .zip file itself.
Then to trigger it set up a shortcut key with _Subdiv_beta9 as the command name.
14 Jul 2018   [#483]
don't forget the first "_" at the beginning of the name! ;)
you can have any upper or lower letters but not space in the name!
_subdiv_Beta9
_subdiv_beta9
_SUBDIV_beTa9
will work :)
