Full Version: Polygonal Converter.
Show messages:  1-6  …  367-386  387-406  407-426  427-446  447-466  467-483
10 Oct 2015   [#427] In reply to [#426]
Gave it a pretty good workout Max... Seems to always work well for how I was using it!
Did some fooling around with using SubDivClassic as a means to "un-subdiv" the parts... Seemed a way to "kindof" revert, but with shrinkage...
Wondering if the "shrinkage" is something that is more or less a known factor, or is it more arbitrary with different geometries?
I didn't want to push too deep into your future plans with the tool.....
10 Oct 2015   [#428] In reply to [#426]
<< So it's not a good idea for me to mark text lines with comments. I'll think what I can do.
In my Text editor (NotePad ++) some word to translate are automaticaly in "Bold" but that not explore all! ;)
So maybe number line, color line, extra color word, ...
French version updated! )
http://moiscript.weebly.com/subdivision.html
10 Oct 2015   [#429] In reply to [#422]
Just a question :
In your example, what is the command to directly split surfaces of the solid
is OK to use Separate ?
Also :
It will be great if Subdiv command wasn't destructive like Subdivision Surface in C4D ?
thanks a lot Max !
10 Oct 2015   [#430] In reply to [#429]
<< In your example, what is the command to directly split surfaces of the solid
Maybe Select Face(s): Edit / Separate
Select All
Call _subdiv_beta9
And if you subdivide again the result you have a funny rugby ball! ;) (Not shown following)
Message 6674.431 was deleted
10 Oct 2015   [#432]
Hi Max.
That last post gave me an idea. Love this script. I have already donated some money but plan to give more in the future, Thanks so much. I am teaching 1st year London university students - Moi and Rhino. I think they will love this. My quick "Eames" chair.
10 Oct 2015   [#433]
BurrMan
This "shrink factor" depends on many parameters, and may varies from vertex to vertex. It will not be easy task to revert subdivided shape to its original state.
I'll try to find information about it tomorrow.
Frenchy Pilou
I will think about built-in multilanguage support.
Finema
Yes. This is the best way. I use it too.
3dcnc
Thank you very much! I'm happy that my scripts is useful for you :)
10 Oct 2015   [#434]
I thought this paper might be of interest:
Conversion of trimmed NURBS surfaces to Catmull–Clark subdivision surfaces.
http://www.sciencedirect.com/science/article/pii/S0167839614000624
11 Oct 2015   [#435]
Hello all
I'm sorry but how do I install this script?
Were do I place the 2 files?
I'm on mac.
11 Oct 2015   [#436] In reply to [#435]
Hi Paulo,
I've just now added an answer to this in the FAQ section of the wiki, please check it out here:
http://moi3d.com/wiki/FAQ#Q:_How_do_I_install_a_plug-in_script.3F
11 Oct 2015   [#437] In reply to [#436]
French version updated! ;)
http://moi3d.com/wiki/QUESTIONS_FREQUENTES
12 Oct 2015   [#438]
Hi all,
I've got some pretty simple solids set up and constantly get an unsupported polygon pop up - am I not understanding a crucial concept?
Cheers,
- Rich
12 Oct 2015   [#439] In reply to [#438]
This mean, face polygon has more than 4 sides
Make it 4 sided, (only 3 or 4 sides supported)
12 Oct 2015   [#440] In reply to [#439]
Ah okay great thanks for that
- Rich
12 Oct 2015   [#441] In reply to [#68]
you are really the master of great scripts.
accidently found this...
a while ago i was looking for a way to further modify OBJ files.
this is the only solution i found so far.
(and MoI makes it really easy to re-model the surface parts where needed.)
2 Apr 2016   [#442]
Hey Max,
I'm a huge fan of your scripts and just now work on a design that requires the translation from Subdivision Surfaces to NURBS.
I have one problem though:
Everything works great as long as only two edges meet to build a sharp edge, but in my model I have several places where more edges meet and I wonder if it's possible to solve that somehow?
Here is my Model in Softimage XSI with hard edges applied (the blue ones):
And this is the result in MoI with your script:
I probably could remodel all those edges by hand, but they are many and I wonder if you would have an idea how to deal with it automagically ;-)
If I preserve corners I get rather weird results that are not usable.
It basically would need to keep the rounding but make the corners sharp only where several cuts/corners meet.
Thank you VERY MUCH!!!!
Cheers,
Tom
3 Apr 2016   [#443] In reply to [#442]
Thought some more on how this could be implemented:
If recognising the cross-points automatically is a problem, maybe we could select the points we want to stay sharp before we apply the script?
But I guess you would still need to somehow pick up the continuity between the parts...
BTW. My illustration above from MoI contains some selection errors, in both cases there would be four hard lines that meet in one point if it would be the same as in XSI, but I also have corners where three hard edges meet.
If there is anything I can do to help, please let me know.
Cheers,
Tom
3 Apr 2016   [#444] In reply to [#443]
Another question:
I checked for a while now, but seem to be unable in MoI to separate an edge.
How would I go about separating edges that are not separatable by a polygon selection?
Like splitting one edge in a ring of polygons? Can that be done at all?
Sorry if I miss something obvious here... ;-)
Otherwise I would have to try if it can be done by separating the polygon edge before import...
Cheers,
Tom
3 Apr 2016   [#445]
If you select all edges and then do a copy and paste you should have all edges as curves.
Is that o.k. for you?
3 Apr 2016   [#446] In reply to [#445]
Thanks Stefan,
my question was maybe unclear: I want to do the conversion from OBJ to NURBS, but want sharp corners inside for instance a Ring of polygons (just as a simple example, my real objects are more involved):
These are four polygons (a cube with top and bottom removed) and one sharp edge. I have not found a way in MoI to "disconnect" an edge like that so that the script can treat it as "sharp".
But somehow I feel it would be even better if we would not have to disconnect the pieces for sharp corners but could simply select the edges we want sharp and the script would work from there. The disconnecting has some disadvantages that I guess would be easier to solve with selected edges instead, since you would still have a whole, connected mesh.
I looked at the script but the math is over my head, so I can't directly contribute other than with some brainstorming on possible approaches and workflow.
Cheers and thanks!
Tom
