361-380
381-400
401-420
421-440
441-460
461-480
481-483
Hi Max,
Yes sorry, I didn't understand the 'stitching' term (my bad).
And I'm pretty sure you all ready talk about it previously, but boy, ... this is the longest MoI thread ever created I guess :)
Thanks for you dedicated work !
Beta9
- loadMesh function has been improved
- increased overall stability
To get hard edges just split object to several surfaces and then run script.
Max, this is absolutely amazing! Can't wait to play with it. :-)
That's awesome, thanks!
Cool trick for the "crease borders" ! :)
Here the French Version (even with the Alert Messages that i have never think to translate! :)
http://moiscript.weebly.com/subdivision.html
@Max
Can you put something on each start lines code (or before each line) where there is something to translate ?
Because it's an hard work to refind all lines that must be translated in your tremondous codes when there is no ressource file!
Thx by advance for that! :)
/* Careful Pilou next line something to translate! */ or something more smaller like /* */ if you want or more smaller if exist or color words or... :)
| <moi:CheckButton id="preserveCorners" default="true">Preserve corners</moi:CheckButton> |
Beta9 update. Fixed bug with polar triangles with open edges.
Frenchy Pilou
When I write a complex script I always use a lot of comments. And I delete them automatically before publishing.
So it's not a good idea for me to mark text lines with comments. I'll think what I can do.
Gave it a pretty good workout Max... Seems to always work well for how I was using it!
Did some fooling around with using SubDivClassic as a means to "un-subdiv" the parts... Seemed a way to "kindof" revert, but with shrinkage...
Wondering if the "shrinkage" is something that is more or less a known factor, or is it more arbitrary with different geometries?
I didn't want to push too deep into your future plans with the tool.....
<< So it's not a good idea for me to mark text lines with comments. I'll think what I can do.
In my Text editor (NotePad ++) some word to translate are automaticaly in "Bold" but that not explore all! ;)
So maybe number line, color line, extra color word, ...
French version updated! )
Just a question :
In your example, what is the command to directly split surfaces of the solid
is OK to use Separate ?
Also :
It will be great if Subdiv command wasn't destructive like Subdivision Surface in C4D ?
thanks a lot Max !
<< In your example, what is the command to directly split surfaces of the solid
Maybe Select Face(s): Edit / Separate
Select All
Call _subdiv_beta9
And if you subdivide again the result you have a funny rugby ball! ;) (Not shown following)
Message 6674.431 was deleted
Hi Max.
That last post gave me an idea. Love this script. I have already donated some money but plan to give more in the future, Thanks so much. I am teaching 1st year London university students - Moi and Rhino. I think they will love this. My quick "Eames" chair.
BurrMan
This "shrink factor" depends on many parameters, and may varies from vertex to vertex. It will not be easy task to revert subdivided shape to its original state.
I'll try to find information about it tomorrow.
Frenchy Pilou
I will think about built-in multilanguage support.
Finema
Yes. This is the best way. I use it too.
3dcnc
Thank you very much! I'm happy that my scripts is useful for you :)
I thought this paper might be of interest:
Conversion of trimmed NURBS surfaces to Catmull–Clark subdivision surfaces.
http://www.sciencedirect.com/science/article/pii/S0167839614000624
Hello all
I'm sorry but how do I install this script?
Were do I place the 2 files?
I'm on mac.
Hi Paulo,
I've just now added an answer to this in the FAQ section of the wiki, please check it out here:
http://moi3d.com/wiki/FAQ#Q:_How_do_I_install_a_plug-in_script.3F
French version updated! ;)
http://moi3d.com/wiki/QUESTIONS_FREQUENTES
Hi all,
I've got some pretty simple solids set up and constantly get an unsupported polygon pop up - am I not understanding a crucial concept?
Cheers,
- Rich
This mean, face polygon has more than 4 sides
Make it 4 sided, (only 3 or 4 sides supported)
Ah okay great thanks for that
- Rich
361-380
381-400
401-420
421-440
441-460
461-480
481-483
