6-25
26-45
46-51
FlowExtendSurf
https://moi3d.com/forum/index.php?webtag=MOI&msg=9747.7
For MoI serif font Times New Roman, used the sweep technique with two 45 degree lines, for D and R. Manual trimming required. Did C with Merge. The 3d letters look good.
Cheers chaps will take a look at some of these routes but not likely to dive into fusion at moment.
Unless it's easy to get a finished result...
@Brian- I presume setting the 45degree line at a length greater than the widest 'stroke width'
of the letters should cover most shapes and mean minimum extensions required....
Btw...i also challenged a friend (autocad expert user)
with these but he was not confident he could do any faster.
Work in progress!
Somehow, my custom style colors reverted to default. Colors were easily restored from AppData colors2020...3dm file.
-B
The more speedy will be to found a 3D Font yet existing and with nurbs export 3D format!
https://www.adobepress.com/articles/article.asp?p=1743636&seqNum=2
Only 256 - 33 - 2 characters to do. Times 5?, plus unicode, plus spacing + ? :-)
I wonder if Flow could convert the 3D fonts to italics?
Bold?
Only about 306,729 +/- fonts exist today, to search. (per one website:-)
Would the 3D font actually be classified as a font?
6-25
26-45
46-51
