Full Version: Boolean
Show messages: All  1-4  5-9
2 May   [#5] In reply to [#3]
Thank you PILOU,
but I prefer that you deform it
2 May   [#6] In reply to [#5]
It's deformed (an arc surface against a flat line surface! ;)
And of course you can give any form at the target ribbon surface!
11 May   [#7] In reply to [#3]
WOW...this is good to know. I never did understand the deform tool. We need more postings like this on using some of the more advanced tools.
I've always had hit or miss with the network tool. Some times it works other times after an hour or so of fiddling I simply give up.
11 May   [#8] In reply to [#7]
http://moi3d.com/4.0/docs/moi_command_reference7.htm#network
Normally result is quasi instantaneous ...if not curves are not well positionned between them ! ;)
Else Flow is terrific for project deform any volume on any other one! :)
12 May   [#9]
A cool use of the Network function... as direct modeling! :)
Of course you can use it on a more elaborated "Volume"! (with the other modes following positions of curves! )
Here just a simple surface! :)
