Full Version: Writing on a oildrop
Show messages: All  1-5  6-15
22 Oct   [#6]
Here is the file
2.3dm
22 Oct   [#7]
As brian said, you don't have to flow line to line but surface to surface.
Now you have to do choice how you do the target surface :
- iso curves and cutting
- boolean cutting
- another method you choose ?
22 Oct   [#8]
Thank you all, but could you explain it a little more precise
22 Oct   [#9]
First, Flow use source and target to adapt objects from source to target.
Those Source and target can be both curves or both surfaces.
Documentation for Flow is here
http://moi3d.com/4.0/docs/moi_command_reference8.htm#flow
Documentation for Iso
http://moi3d.com/4.0/docs/moi_command_reference7.htm#isocurve
You have to turn your drop to avoid problems with cutting an edge next.
Use ISO curve -----> Construct/Curve/ISO
When you have your curves, you can select drop + Curves and Trim it -----> Edit/Trim
Now you have a surface which could be a target surface.
Construct a rectangle on your Text which could be a source surface.
You can now use the Flow function -----> Transform/DEform/Flow
If you want delete the cutting of your drop, select text on drop Copy it with Ctrl/C
press Undo many time to return on the situation you want then Paste iwith Ctrl/V
2_01.3dm
22 Oct   [#10]
Size of flowed text could be adjusted by:
Change 2d rectangle size.
Or change text size,
Or ...
Ratio of height to width may also change, unless...
22 Oct   [#11]
As Brian wrote it, I explain the theory to be easy understood.
Next you can tune your process as Brian wrote it if you want a better result by modifying your source or/and target surfaces.
22 Oct   [#12]
Thank you all. I will try it tomorrow.
25 Oct   [#13]
My preminilary result
25 Oct   [#14] In reply to [#13]
Very good result!
Can alignment of text be slightly changed by moving and/or slightly rotating base surface?
26 Oct   [#15] In reply to [#14]
I didnĀ“t try it.
