Full Version: "make2d" oddities
Show messages: All  1-7  8-19
28 Mar 2023   [#8] In reply to [#7]
There's also a select by length script here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7927.2
28 Mar 2023   [#9] In reply to [#8]
That is a good script.
In Burr's script list, there is also "SelectAllLengths.js."
Maybe one of those 3 scripts, or some combination, could have some user size entry input added?
28 Mar 2023   [#10] In reply to [#8]
After a join, I tried your linked script, with min 0.0 and max 0.2, which identified 7 segments for deletion.
28 Mar 2023   [#11] In reply to [#6]
Thanks for the file. I looked at it, but like bemfarmer already mentioned, it still does not
quite give me the desired results. I will play around with those additional scripts you mentioned.
Are there any plans to work on this in the future. In my case it would be nice to have a clean output
in one go. But this is probably not something most users require.
Ad
29 Mar 2023   [#12] In reply to [#11]
Hi Ad,
You might give Rhino a try since someone else on this forum said that v5 didn't have these problems:
http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=6201.288
I delete the fragments manually because I have found that a silhouette that ends in the middle of a double-curved surface has a similar artifact where it ends, and that the piece that should be hidden, but is rendered as visible, is joined to the rest of the silhouette curve and so isn't a "short" curve that can be found with a script.
But, if the problem is basically that you want to get closed curves that can be filled, I recommend Adobe Illustrator's LivePaint. It does a good job even when there are little gaps and other problems. Expanding the LivePaint group gives closed shapes that can be stroked, offset, filled with a gradient, etc. You might also try Inkscape's Fill Bounded Areas if you haven't already. The way it works is pretty different from LivePaint and so the results aren't as good, but it might get the job done.
- Peer
29 Mar 2023   [#13] In reply to [#11]
Hi Ad,
> quite give me the desired results. <...>
It's a step closer to your desired results because several of the problems you originally noted are not there.
If you generally keep objects to be exported about the size I showed it should help some.
> to have a clean output in one go. But this is probably not something most users
> require.
It's a tricky area because it's very easy for a fix that solves one problem to cause a new problem somewhere else.
But if you report problems especially providing a .3dm file so I can reproduce it then that can help me to work on tuneups.
Maybe some different behavior specifically for silhouette curves would help, something like don't try to determine visibility on a silhouette curve until it has taken a few steps already.
29 Mar 2023   [#14] In reply to [#13]
>It's a tricky area because it's very easy for a fix that solves one problem to cause a new problem somewhere else.<
I see what you are saying :). Your solution works. Scaling the model up and changing the resolution makes those short
segments almost invisible, or invisible enough to get away with it, in most situations. In my case it might actually be
easier to not scale the model, so it is easier to spot the problem areas and fix them.
Another thought that came to me, would it be possible to automagically have all the line segments, that surround each
face joined. I probably should make a screenshot to show what I mean. Or is there a way to loop select edge loops on 2D
entities. I know there is script that works on faces. I am just trying to avoid to chase files from one program to another,
and Moi just has a nice workflow.
@Peer, yeap LivePaint works really very well, played around with this too. Corel Draw has a similar function, I think it's
called FloodFill, not sure right now, also works well. Inkscape solution works, but this is really not there yet :(. FreeCad was
another thing I tried (Tech Draw Workbench), this gave me the proper result, but, FreeCAD is a "Beast", if you know what I mean.
It is loaded, but simple things are sometimes better/easier/faster. Right now I am just exploring my possibilities and looking
for the best solution.
Sorry for the long post.
Ad
29 Mar 2023   [#15] In reply to [#14]
Hi Ad,
> that surround each face joined.
Pretty difficult to make that happen currently at least. To start with as you have noted there are often little pieces which are hard for a joiner to process automatically.
Additionally on edges shared between 2 faces those would need to be duplicated?
> loop select edge loops on 2D entities.
Sorry, no there isn't that kind of loop selection available currently.
29 Mar 2023   [#16]
And why not use the PDF export from MOi3D ?
Seems you have the same different projects view 3D of any position of the object in the 3D SPace to the flat sheet !
and seem there is no problem of intersection and little part of curves... at the 500% zoom
30 Mar 2023   [#17] In reply to [#15]
>Pretty difficult to make that happen currently at least. To start with as you have noted there are often little pieces which are hard for a joiner to process automatically.<
Sorry I threw that at you. I haven't really thought through this, I just thought out loud. But after some more thinking, I realized this is probably a
no-go. And like you said, on top of that, some edges would have to be duplicated.
@Frenchy Pilou, the pdf export was actually the first thing I did, but if I have to clean up things, it is actually easier to do right there in Moi. At least for me.
Thanks to everybody for your input and suggestions, definately got me a step further.
18 Apr 2023   [#18] In reply to [#17]
Hi Ad,
Have you tried out the latest v5 beta? It seems like hidden line removal is less sensitive to object size now.
- Peer
20 Apr 2023   [#19] In reply to [#18]
Hi Peer,
I just used make2d with a different part, on the April 8 Beta.
The results were much better, but like I said this was a different
part.
After trying several different options, including other software,
I decided to stick with Moi. Just have to do some clean up, but
either way I have to prep things for my purpose anyway and doing
it in Moi is the most efficient way for me personally.
Ad
