Make2D - merge overlapping lines
9811.2 In reply to 9811.1
Hi Franz, there is a "RemoveDuplicates" command which might help for that:
http://moi3d.com/3.0/docs/moi_command_reference10.htm#removeduplicates
quote:
Currently only works on curves, removes other curves that are duplicates within a specified tolerance (curve endpoints must be in tolerance too).
The RemoveDuplicates command does not currently have a button in the UI, it must be set up on a keyboard shortcut (under Options > Shortcut keys) or have its command name typed in (press Tab first to enter a command name) to launch it.
Removing overlaps that do not have the same length is a lot more difficult.
