2D Scale (from/along) an arched center line
8808.2 In reply to 8808.1
Hi Ivan, so do you mean something like modify a curved object from one centerline path to another?
There is a "Flow" command in MoI that can be used for that, there is some information on it here:
http://moi3d.com/3.0/docs/moi_command_reference8.htm#flow
Usually it's used to map objects from a straight line onto a curve but it's also possible to map between 2 curved centerlines as well.
It might help if you could give some more details about what you're trying to do.
