Open Curves on surface
8296.2 In reply to 8296.1
Hi Berube, I'd need to look at your 3DM model file and possibly repeat your construction steps to answer your question about where are those segmented edges coming from.
If the segments are smooth to each other you can use the Merge command though to glue them together into a longer edge:
http://moi3d.com/3.0/docs/moi_command_reference10.htm#merge
