Scaling issue
6950.2 In reply to 6950.1
Hi gunter, select one of your ribs, then run the Transform > Scale command.
Look in the upper-right corner of the MoI window to see the command prompt which tells you what MoI is expecting for you to do next.
The first prompt is "Pick origin point". In the top view, pick the point here:
After you've picked that point, the next prompt says: "Pick first reference point", here you can pick a point for a base distance or you can type in a scale factor if you know it. In your case, pick the point here:
The last prompt says "Pick second reference point", pick this point here (all picks in the top view so they'll all be on the same plane):
Does that do what you need?
There is some additional information on how the reference points work for the Transform > Scale command in the reference section of the help file here:
http://moi3d.com/3.0/docs/moi_command_reference8.htm#scale
You can also use the Transform > Orient > Line to line tool to scale things into place like this, that works by picking 2 base points and then 2 target points and will rescale and also rotate things to match from the first line to the second line.
You can also use the edit frame scaling grips to do this type of sizing as well, you will need to do one click and release on a corner grip in order to change the origin mode from center to opposite corner.
