Hi Mike, re:
> I can't seem to get this script to work. Any thoughts installation etc..?
> Message reads: Can't find variable:Randomize
Please double check the instructions here at FAQ #1.
That error message means that MoI tried to run the contents of your shortcut key command text as direct immediate script code. It will do that if it could not find a file of that name in the commands folder, or if you have set up the shortcut key command with a "script:" prefix on it (like if you shortcut key command is set up as script:Randomize instead of just plain Randomize).
If you have just plain Randomize as the shortcut key command then it means that the Randomize.js and Randomize.htm files are not getting copied into the commands folder, so double check that and restart MoI after you have copied them.
