Object Cost > Script
12020.1
This is a quick utlity script
It uses object name as the 'calculator input'
Simply name objects as you would normally do,
then append the price at end after ">"
Example:
"YourObjectName>16.15"
anything after ">" is counted.
1 object selected = 16.15
10 objects selected = 161.15
8 objects selected:
Seems to work...ok..if any bugs or new requests or suggestions please provide feedback.
Other:
You can also set currency symbol in the code, or if currency copied to clipboard
or not. I prefer to choose "false" so: 129.90
you can change to "true" if you want to get $129.90.
// ObjectCosts.js
// Calculates total cost from selected object names.
// Naming syntax: Material description >20.50
// Example: "Polycarb Clear 2mm >20.50"
(function(){
    var currency = "$";
    var copyCurrencySymbolToClipboard = false;
    function formatClipboardAmount( amount, currencySymbol, includeCurrencySymbol )
        if ( includeCurrencySymbol )
            return currencySymbol + amount;
        return amount;
    var objs = moi.geometryDatabase.getSelectedObjects();
    var total = 0;
    var found = 0;
    for ( var i = 0; i < objs.length; ++i )
        var name = objs.item(i).name;
        var m = name.match(/> *([0-9]+(?:\.[0-9]{1,2})?)$/);
        if ( m )
            total += parseFloat(m[1]);
            found++;
    var amount = total.toFixed(2);
    var clipboardText = formatClipboardAmount(
        amount,
        currency,
    moi.copyTextToClipboard( clipboardText );
    moi.ui.alert(
        "Found prices on " + found + " object(s)\n\n" +
        "Total = " + currency + amount + "\n\n" +
        "Copied to clipboard: " + clipboardText
This script should go into usual place; moi app data commands folder and/or be assigned to a shortcut key
You can also use command line typing: "Objectcosts"
Resources:
Install scripts
Assign shortcut keys via options/shortcuts
EDITED: 12 Jun by LIGHTWAVE
