Hi All,
Pleased to attach v1 (.21) of 'Command Palette' .
I really like this script when assigned to the 'accent-key' directly above tab and below escape...
as i find it then totally complements my workflow and works with moi not against it,
You can assign then open the script from any shortcut key. Once opened simply type straightaway.
Partial or fuzzy searching allowed. Press enter to run. Also, up/down keys work nicely. Hit escape twice to exit..
No need to remember all those more obscure shortcuts with this or call up long
script or command names in full. You can type shorthand or remember things like 'boo-lean or rude, extrude,
fi-llet.
many thanks to Michael for sorting out the loop to get the search box nice and responsive..
This tool originally started in autohotkeys, but i wanted it a lot more responsive or moi-integrated
All / any feedback is welcome.
Edit
#1 uploaded slightly tweaked version works ok with dark theme ref - Phiro
#2. Resources:
Install scripts
Assign shortcut keys via options/shortcuts
