Select all faces inside an edge loop?
11003.5 In reply to 11003.4
Hi Chris, try the attached SelectFill plugin.
Instructions for installing a plugin here.
You'll need to set up an edge selection first, like this:
Then when you run it, you need to pick a face:
And then only faces inside the same zone bounded by the edges should get selected:
Hope that was what you were looking for.
