On static and dynamic display of dimensions ; and converting annotations to lines.
10990.8 In reply to 10990.6
Hi Pior,
> The ability to copy-paste dim styling properties from one to another
At some point I'd like to add controls for this into the object properties dialog.
Until then I've attached a MatchAnnotationProps command that can do that job.
To use it, select the dim you want to modify, then run MatchAnnotationProps, then select the object you want to match up with.
Instructions for installing a plug-in here.
