Some future requests or maybe they exist (weld, Extract surface and 3d boolean merge)
10622.3 In reply to 10622.1
Hi Matadem,
> Quick question is there a script to simulate weld beads?
You might try drawing a circle and then using using Construct > Sweep to sweep the circle around edge curves to make a tube.
There is a Pipe script that automates that here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1463.48
But that may look too clean, if you want a realistic looking weld bead that's probably something that would work better in a pollygon mesh brush sculpting type program rather than in a CAD program like MoI. Do a web search for something like: zbrush weld bead to get some examples.
> Is this possible as a addon in the fillet/ chamfer menu?
Not likely, it would be a kind of odd thing to try and incorporate in a CAD program because CAD geometry is not suited for making geometry with high frequency bumps and lumps in it, that fits better with polygon modeling geometry.
> The question would be I have 3d object (pic attached) is there a way to select
> all the surfaces and line them up in a single plane? unfold kind of.
There isn't any tool in MoI for doing that but there are other programs that could do that for you. Check out some previous discussion here for some links:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=5550.1
http://moi3d.com/forum/messages.php?webtag=MOI&msg=5463.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=3042.8
Some other discussion here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8126.1
Some other programs to check out are Form-Z and AutoPol unfold:
https://www.autopol.com/products/unfold/
And also Alibre has some sheet metal tools too I think.
> 3d boolean merge ... cutting object in 3d view...I know that I could create 3d plane and boxes to cut out shapes which I did.(but time consuming)
You can try this script to set the construction plane to the current 3D view direction, then the regular draw tools will draw in that view plane:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2599.4
