Construction line question?
All  1  2-16
991.2 In reply to 991.1
Hi Paul, there aren't currently any kinds of per-object color properties. Those are definitely something that will come with v2.
But I think I should be able to expose a property on construction lines that would make it possible to keep them with a keyboard script macro, I'll see what I can come up with later today.
I've thought about making some method to optionally keep them before as well, but I haven't been able to figure out a good place to put the UI for it yet...
991.3 In reply to 991.2
Sounds good!
Paul
991.4 In reply to 991.3
Hi Paul, it looks like this will work. I've added a new "isTemporary" property for construction lines. By default it is true but if you set it to false then it won't get erased at the end of the current command.
So this enables setting up a keyboard shortcut like K to keep construction lines with this as the command:
script:moi.geometryDatabase.getObjects().getConstructionLines().setProperty( "isTemporary", false );
And then maybe something like Ctrl+K for removing them by doing this:
script:var gd = moi.geometryDatabase; gd.removeObjects( gd.getObjects().getConstructionLines() );
They will persist until you erase them or something erases the entire geometry database (like File / New or Open). But they won't save to a .3dm file right now, that will have to wait for a later version.
For this to work you will need an updated moi_lib.dll, I have a couple of other things I want to try before posting a new patch, I think it might be a day or two before I am ready to post it.
Persistant yes, but are they keep their snap power?
991.6 In reply to 991.4
There will be a couple of quirks that will be hard to avoid for a little while - if you do a select all or invert, the persistent construction lines can get selected even though they don't show it, they will then get removed if you do a delete.
991.7 In reply to 991.5
Yup, you can still snap on to them and find the intersections with other things. There isn't any way to re-activate the menu for the stuff like relocate or reorient though, you can only do those special editing operations right after you have drawn a construction line.
991.8 In reply to 991.7
Thanks, Michael, it sounds like what I've been wishing for --
I appreciate your efforts!
Paul
PS. - While I remember, thanks also for your patience vis-a-vis scripting questions! It helps alot -
991.9 In reply to 991.7
<There isn't any way to re-activate the menu for the stuff like relocate or reorient though, you can only do those special editing operations right after you have drawn a construction line.
it's yet not so bad :)
991.10
Hi Michael and Forun Friends
I try the script to activate (Keep Costruction line, but it's not run , when hold K key show
this message ?????
What's mean .....
again
I ask you will be ,in the futur , for Moi user the Plug-in Tspline
actually for Rhino ??
Tnx
Sorry for my English
Al
991.11 In reply to 991.10
Hi Al - that message means that there is an error in the script.
The script that I showed above won't work in the current beta, it will only work in the next patch that I will be putting out soon, maybe tomorrow I hope.
I don't know... Maybe it will be possible in the future. It will be a while before I will be able to make MoI work well for doing plug-ins. Doing plug-ins takes quite a bit of support and documentation work, I won't be able to do it until a ways in the future I think.
991.12 In reply to 991.11
The new patch is not quite ready yet, but it should be tomorrow. I'm just trying a new "axis" snap which basically works like a permanent construction line running along the x and y axes of the grid.
991.13 In reply to 991.12
Hmmm, still working on a few last details for the new axis snap. The patch may be ready later tonight, but it might stretch into tomorrow...
991.14 In reply to 991.13
The patch still isn't quite ready yet, sorry... stretching out until tomorrow.
991.15 In reply to 991.14
No great rush -- it'll be done when it's done ! :)
Paul
991.16 In reply to 991.15
Hi Paul, ok it is done now! I got kind of stuck on a bug with the new axis snap for a while there.
link is here: http://moi3d.com/forum/index.php?webtag=MOI&msg=1013.1
With that patch in place, the above "keep construction line" script should now work.
Show messages: All  1  2-16
