The Globes and the Dimples
 1-20  21-40  41-44
979.41
Hey
Anthony also made a 2.5 version, which can be located here:
http://chronosphere.home.comcast.net/~chronosphere/true-normals.htm
979.42 In reply to 979.41
Hi All,
Just wondering if there's still a blender importer out there for MoI?
Thanks!
979.43 In reply to 979.42
Import a Blender file inside MOi ?
you can use directly OBJ files with the Max Smirnov _importOBJ or the new native Transform / SubD
You can also use FreeShip to export in IGES format, the "subdivision surfaces" made with Blender.
I believe that Blender has not yet Nurbs Volumes!
EDITED: 16 Jan 2020 by PILOU
979.44 In reply to 979.42
Hi jweber, if you mean importing files made in MoI into Blender, it used to be the case a long time ago that a special importer was needed to have vertex normals come through. But Blender's default .obj file importer has been improved a lot since then so now there is no need to use any special importer, just use .obj format for transferring into Blender.
Show messages:  1-20  21-40  41-44
