Modify an entity
971.1
Hi Michael:
In a future you do to include a very useful function that double click is to modify an entity, does it line, circulate, arch, curve, square, etc?
Best regards
Juan Galvan
971.2 In reply to 971.1
Hi Juan, yes I do want to have that function for version 2.0 .
I think maybe not on double-click, but just when you select an object I want to have a properties panel that shows up where command options currently go, that will let you change various properties of the object, including things like the radius of a circle, etc...
971.3
Hi Michael:
It is very complete the definition in the future of V2 some designer maybe includes CAM in a future as plug in or compatible program.
Best regards.
Juan Galvan
971.4 In reply to 971.3
Hi Juan, probably a CAM plugin won't be possible in V2 - it takes quite a bit of time to document and support a plug-in system. I don't think that it will be likely to happen before V3.
But a compatible separate program is certainly possible, especially since MoI uses the .3dm file format which can be easily read by other programs. I would think that there should already be stand-alone CAM programs (not plug-ins) that should be able to read in .3dm files right now...
