What is your regulates Moi--> ZBrush
 1-16  17-36  37-41
804.37 In reply to 804.36
> "With SMT Button pressed mesh will be Smoothed then Divided"
Yes - it looks like ZBrush has some kind of bug in the smoothing process, looks like it may have to do with processing polygons that have a high valence vertex in them. That's a vertex that has a large number of edges radiating out from it, which is the case in pole points like that.
Vertices with a high valence can have some difficulties in certain smooth subdivision schemes.
So turning off the smoothing process avoids the problem in ZBrush.
804.38
Very informative thread.
In ZBrush if you turn on Polyframe while using Dynamesh you can see that the mesh is made up of quads and triangles.
804.39
Here's a cutlass made in MoI and imported into ZBrush using the method previously outlined.
MoI
ZBrush
804.40 In reply to 804.12
804.41
This method is also excellent for bringing MoI models into 3D-Coat for voxel sculpting!
Show messages:  1-16  17-36  37-41
