split lines in sweep
 1-9  10-29  30-31
744.10
Actually, drawing a curve though points will not be exactly the same as the 2 joined curves. there can be huge differences. Because points are assigned varying weights, depending on what type of curve being drawn, and depending on it's proximity to the end of a curve. When you draw a new curve through points, the new points are not weighted in the same manner. and Moi has no system for adjusting point weights... so you will always have to decide what is an acceptable deviation for your model when joining and deleting a point, no matter how you attempt to clean it up...
jonah
744.11 In reply to 744.10
Ummm, some bezier curves in MOI would be a yummy thing, fo-sho...
-Will
744.12
only if you want to develop really bad nurbs objects. Bezier curves are the devil... :)
shorty
744.13 In reply to 744.12
okay, perhaps I just meant >handle bar< editors for the existing points - similar to Rhino...
-Will
744.14 In reply to 744.10
Hi Jonah,
You made a good point about tracing a curve...it will not produce the exact same geometry, In my example, I was kind of sloppy..the curves don't match very well.
In Rhino, there will always be some deviation from the original if you match curves with "curvature" or "tangency" and merge or join them, or if you rebuild a segmented curve into a continuous curve, but depending on the number of control points you can live with, it's usually a very negligible deviation.
If you trace a segmented curve with enough control points in MoI, it will be, ( as they say) " close enough for government work" or good enough for jewelry design, in my case. :-)
-Jesse
EDITED: 11 Jul 2007 by JESSE
744.15
if you want to remove that crease without varying the curve too much, you can first join the curves, then add 3 control points on each segment at position very very close to the join point. Then delete the join point. Assuming it's a nurbs curve of no higher than degree 3, the effect will not extend past that 3rd new point...
jonah
744.16 In reply to 744.13
Hi Will,
You mean like the HBar command in Rhino?
The main useful part of HBar is actually already built in to MoI - you can activate it by dragging on an unselected curve that has control points turned on.
For example - if you have this curve, if you click and drag from here:
You will get this dragging effect, same as if there was an HBar there and you were dragging the middle point of it:
This allows you to drag a point directly on the curve from where you dragged to a new location, you sort of grab a point directly on the curve with this mechanism. It's basically a way to manipulate several nearby control points all in one single motion, so it can be useful for kind of roughing out and making big changes to a shape.
This is a lot better than a dedicated command because it is always implicitly available just with a drag gesture on an unselected curve (if the curve is selected then you will drag the entire curve). HBar as a dedicated command is really quite awkward, you have to worry about firing up the command and repeating it a bunch of times... Also HBar in Rhino requires more clicks - you can't just click and drag on a portion of the curve, you have to click once to place the handlebar, and then click again on the handlebar to drag. This actually wasn't the case when I originally wrote HBar, it looks like that got a bit messed up in Rhino.
Re: full Bezier editor -
Doing a full bezier type editing system would tend to greatly exacerbate the original problem here about having multiple joined segments.
A Bezier editor creates curves that are made up of tons of little separate individual curves joined together into a long string. Each little piece is made up of 4 control points. It forces shared tangents by moving points together to be in a straight line between each little piece, but it generally does not produce shared curvature between each piece. So I'm not really planning on doing anything like that, it just does not create as high quality of smooth curves as the current NURBS system in MoI.
NURBS were essentially invented as a solution to this problem with chaining together lots of little individual Bezier curves! The mathematics are related, I mean NURBS builds on a lot of Bezier mathematics as a foundation, but it provides a way to have a smoother curve when you have more than 4 points.
Doing a Bezier style editor would be kind of taking a step backwards technology-wise...
744.17 In reply to 744.16
Absolutely WOW Michael!
(Please tell me, I'm NOT the only one that didn't know this could be done???!!)
Reminds me of the saying how when an elephant has been chained to a post long enough that you can remove the chains and it won't try to escape thinking it's still chained!
I've been so used to only being able to drag directly on the control points from all my other applications! I didn't even realize you could also drag directly on the curve!!
Yes, that IS so much better than HBars - again this is why MOI is so much BETTER; the UI is clean, simple and elegant!
Yes, I also understand that beziers aren't as clean as the curves we have now - knowing this additional trick for adjusting the curve certainly makes them unnecessary!
-Will
PS - Please tell me that this trick wasn't written down somewhere in the existing documentation?? Embarassing!
Boy I can't wait for the complete documentation on MOI when it's done!
744.18 In reply to 744.17
:) Actually, it is covered in the primitive introductory documentation on the download page: http://moi3d.com/beta/MoI_Introduction.htm, it's mentioned under the notes for "Show pts".
But I think it is pretty easy to gloss over it there since there aren't any screenshots for it.
The screenshots or video captures that I will include with the proper documentation should help out quite a bit!
744.19 In reply to 744.15
-then add 3 control points
Hi Jonah,
I could very well be doing it wrong, but with the addition of the 6 new points, it drastically changed the shape of my curve...
maybe it works better if there is not a significant curvature? .could you post a before and after example?
Jesse
744.20 In reply to 744.18
That's a very cool feature. Talk about embarrassing...
I remember trying it once, but then I completely forgot it...
What I need is a set of "tooltips" that automatically pops up when
I'm doing something the hard way and suggests a better method.:-)
Micheal,...maybe for version 9? ;-)
Jesse
744.21 In reply to 744.17
It's not too uncommon for 2D Bezier illustration programs to support a version of this, like in Adobe Illustrator you can click and drag directly on a curve when control points are visible to move it.
But actually the behavior of this "direct curve drag" in these Bezier apps kind of highlights the segmented nature of the pure Bezier approach - over there when you click and drag on a curve, the ends of the segment stay anchored and only the interior 2 points are adjusted. This tends to cause curly-cues and it really spazzes out if you try to drag a point close to the end of a Bezier segment, a tiny motion there causes kind of a huge reaction in the curve. It's not really a full "roughing out" tool over there since only the one segment is effected by the drag.
The NURBS-based direct curve dragging in MoI gives a lot more smooth editing results at any point along a curve.
I'm not really sure why 2D illustration apps have never upgraded to use NURBS-based technology instead of only Bezier-based. I guess Adobe Illustrator never did it because Illustrator is kind of part of a larger Adobe ecosystem and it has been meant to be on par with other parts such as the Postscript language. So they probably don't want to upgrade just one thing, they would want to upgrade a whole bunch of things, making it easier to decide not to upgrade at all. Then other 2D illustration stuff follows their lead...
744.22 In reply to 744.19
Hi Jesse - there are actually 2 different ways of adding control points.
Kind of the common way in MoI is to add a new point on the control polygon hull in between 2 existing points. This way will change the shape of the curve though, it will generally be the equivalent as if you had drawn the original curve including those new points you added. That's why it is kind of the normal way because it works equivalent to drawing a curve by control points.
But there is a second way of adding a control point where you can add it directly to a curve without disturbing the shape of the curve (same as InsertKnot in Rhino). This will happen if you click directly on the curve when inside of AddPt instead of on the control point hull. But by default the control point hull (the dashed lines between control points) has priority, so if you have control points showing it can be difficult to grab a point on the curve, but if you turn control points off then you will be able to grab the curve directly for this second mode.
If you add points using the second method, the shape of the curve will remain exactly the same and instead the control points themselves will slightly shift. The first way it is the reverse - the control points stay anchored down and the curve will shift shape instead.
744.23 In reply to 744.22
Thanks for the explanation.. I see how it works differently.
And by adding a "loose" point from the curve menu as a marker,
you can see where the joint is without having to turn control points on.
Jesse
744.24
As michael pointed out, i added the point directly onto the curve. and here is the example of 3 points added very close to the joined end points, and then deleting the end point itself. you can see the change does not pass beyond the 3rd extra point...
jonah
744.25 In reply to 744.21
Michael wrote:
"I'm not really sure why 2D illustration apps have never upgraded to use NURBS-based technology instead of only Bezier-based. I guess Adobe Illustrator never did it because Illustrator is kind of part of a larger Adobe ecosystem and it has been meant to be on par with other parts such as the Postscript language. So they probably don't want to upgrade just one thing, they would want to upgrade a whole bunch of things, making it easier to decide not to upgrade at all. Then other 2D illustration stuff follows their lead..."
Just the other day I was wishing I could do simple surface coloring with MOI since creating shapes with it is so easy - I guess I'll have to wait for the AI export features.
I wanted to load a UV map image of a spaceship wing and start drawing hull plating patterns over the UV map - MOI is great for drawing curves, I wish Fireworks, CorelDraw and Illustrator also used the same kind of editing features as well!
If I could have used MOI to draw my hull patterns and then select a few of the closed shapes and colored them to get some base colors going that would have been great.
I of course can color in my shapes elsewhere but it would have been cool!
-Will
744.26
Theres some great info here, thanks Jonah with that initial suggestion and with Michaels clarification it sounds like a neat solution! I guess you wouldn't want to script this action because you want to choose where the additional control points go yourself, but it's no hassle at all.
Lovely jubbly
744.27 In reply to 744.24
I tried the other method a few times and can see the benefit of removing a joint with control points turned off and using 3 tightly grouped points on each side of the seam point, before removing it, but in practicality, I realized that with the most of the designs I do, I will place a corner point where I want to define the start of a new surface but with that, I either draw straight continuous lines or graceful flowing curves without tightly angled transitions as in Jonah's example. If I remove points to adjust an irregular transition in a curve or remove a seam point, I'm usually editing the shape from a broader perspective anyway, so it seems more efficient for me to keep the control points on, to take out a seam. It's helpful to know how to do it the other way, too. So thanks, now I know there's a method to my madness. :-)
Regards,
Jesse
jdkjewelry3d.blogspot.com
EDITED: 12 Jul 2007 by JESSE
744.28
If you want a fun and easy to use vector illustrator, try Inkscape. It's scriptable with Python, and has all sorts of ways to easily tweak curves. You can just click and hold on any part of a curve, and drag it where you need. No need to use the handles on the control points.
I highly reccomend it, and I also think Moi should support SVG import.
744.29
Michael:
I just wanted to say, clicking and dragging anywhere on a curve to modify it has been in Inkscape for a few releases now... ;)
Maybe you can steal a few of their other ideas as well.... <:)
Pattern along path:
Mmm, imagine this applied to arrays in Moi.
http://www.inkscape.org/screenshots/gallery/inkscape-0.45-patternalongpath.png
Thicken and thin closed curves, and Guide Paths
http://www.inkscape.org/screenshots/gallery/inkscape-0.46-engraving2.png
http://www.inkscape.org/screenshots/gallery/inkscape-0.46-engraving1.png
Drag the Curve to edit it:
http://www.inkscape.org/screenshots/gallery/inkscape-0.43-nodeedit.png
Node Sculpting: ( Think Uber Curve Drag )
http://www.inkscape.org/screenshots/gallery/inkscape-0.44-nodesculpting.png
Show messages:  1-9  10-29  30-31
