Relative start
All  1-3  4-9
628.4 In reply to 628.3
Hi Rozen, you're welcome, I'm glad that works for you.
I have now fixed that problem for the next beta, so that if you set a distance constraint when drawing a construction line, the same distance constraint will not still be active and applying to the regular point pick after the cline is finished.
I've also added a way to turn off distance or angle constraint by putting in a 0 in either the d or angle boxes. Previously there wasn't any way to turn it off once you had turned it on.
> Looks like you can do it in any situation.....
Yup, that's the nice thing about these helper tools like construction lines - once you learn them you can usually use them for any drawing command, whether it's drawing a polyline, drawing a cylinder, etc...
EDITED: 9 Jan 2021 by CHRI
All that works also with a pen graphic?
628.6 In reply to 628.5
It does! Just instead of typing in a number to activate distance constraint, go to the "d" (for distance) box in the bottom toolbar and click on it and enter a number with the little pop-up panel. That will work without ever needing to touch the keyboard.
But actually, I guess you do need to use the keyboard for one thing I mentioned above, the "rx,y" relative coordinate method. There isn't currently any non-keyboard replacement for typing in the initial "r" to indicate relative coordinates.
628.7 In reply to 628.6
Maybe a little more keys on the pop up calculator? :)
R = relative, M O I free :)
EDITED: 23 May 2007 by PILOU
628.8 In reply to 628.7
Pretty soon you'll want the whole alphabet in there! :)
So far this hasn't been an issue because relative coordinates just aren't used too frequently. And if you are using them frequently you would generally want to use a keyboard for entering a larger quantity of numbers in anyway...
628.9 In reply to 628.8
I have just forgotten the "," (comma) for use it with the relative entry :)
So just 2 keys :)
Show messages: All  1-3  4-9
