Tut video Boolean + Curves
All  1  2-8
608.2 In reply to 608.1
Wow, I didn't notice myself that BooleanMerge command worked in this manner. It means the curves can result in solid! Thanks! -Petr
608.3 In reply to 608.2
Boolean merge is very powerfull for "sculpt" an object :)
608.4
Hi all, I tried watching that tut but it didnt load plus I cant read french :( , Guess i should have listened to the french teacher more, dam. Graham
608.5 In reply to 608.4
Nothing to read: it's only visual and make with the english version of moi :)
And nothing to load : tut must start automaticaly! (Flash)
(just wait 10 second the connection)
608.6 In reply to 608.5
I couldn't see it at first either. It helped me by refreshing the page and right-clicking the flash control to make sure it was playing.
Actually at first it stopped playing and I thought the tut was over (just after closing the initial 4 lines at the beginning) but luckly I did a refresh again and realized there was more to it!
Steph should include a trackbar with his videos so you can tell when it's actually complete and not stalled due to a slow download connection...
It was great to see how easy it is to throw stuff together; definitely shows that by thinking outside the box (no pun) you can create some really interesting shapes - quickly too!
Great video!
-Will
608.7
I too was having problems with trying to play the video using both IE and FF. I finally found a program called SWF Opener which will allow you to save SWF's from the browers cache and then play them back. http://www.browsertools.net/SWF-Opener/
608.8 In reply to 608.7
Thx for the trick :)
Show messages: All  1  2-8
