Test big objects by Steph
All  1-3  4-10
607.4 In reply to 607.3
One guaranteed way to speed it up is to buy a faster computer! :)
After you've extruded it, you have a large number of solids there - solids take longer to display than just curves.
There are a couple of things you can do to help speed up the display - under Options, inside "Meshing parameters", set Surface angle and Trim curve angle from the default 10 degrees to 20 or 25 degrees. This will reduce the mesh density that is used for displaying surfaces and solids. Your objects will appear rougher but they will have fewer triangles which reduces the amount of information that is rendered by your videocard, making it faster.
Also uncheck "Add detail to inflections", "Display hidden-line curves", and "display hidden-line edges".
You'll probably want to restore those settings back again after you return to working on a single object instead of a large number of objects.
607.5 In reply to 607.4
Steph computer is a "race beast" :)
EDITED: 12 May 2007 by PILOU
607.6
very good work Pilou :)
607.7 In reply to 607.6
@Torolf:)
It's not me, it's Steph !!!
Watch by Steph !
607.9 In reply to 607.8
That's really cool - it looks like that realtime system can be used to create mini applications?
607.10 In reply to 607.9
< it looks like that realtime system can be used to create mini applications?
Absolutly!)
But it's seems to me that is not for someone who has never coded !
Of course for you no problem :)
XLM, LUA and OpenGL Shading Language (for more realistic shader render)
http://www.ozone3d.net/repository_hyperion_cs_interactivity.php?lang=2
Hyperion : http://www.ozone3d.net/hyperion.php?lang=2
PS This system is freeware for no commercial application!
EDITED: 13 May 2007 by PILOU
Show messages: All  1-3  4-10
