Stupid Newbie question #1
All  1-3  4-17
602.4 In reply to 602.3
Very cool Pilou, that's it! Jeff - that tutorial shows how to set up the texturing in Blender to generate a grayscale rendered image with white as high and black as low areas. That should do the trick.
602.5 In reply to 602.4
hi jeff i currently do cnc wood carvings i us vetric 3d v carve and u can load 3ds files right from moi to there and cut away vectric.com
602.6
Thanks to everyone. Yes, they are working on a 'Professional' version of the software which should allow for the importation of 'standard' file types, and I ave tried and tried to get a beta of it (and I am a forum Mod there and know one of their programmers in a round about way) and have been not been able to :( Their approach in their format in kind of unique as it allows you to import standard formats such as jpg, png, and gif, and it interprets it as a heightmap. I have done quite a few things just using Corel Draw and contours (not my idea BTW, but it works great), this method works but you have very limited control.
I have used Blender to do some very basic height map rendering but I find it's interface to be counter intuitive, the menus are NEVER the same, some kind of modal nonsense that make it impossible to (unless you have a lot of experiance) to get back to someplace you just were. That is one thing I have like about the small amount of time I have used MoI, I could actually draw some basic things in just a few minutes. I may have to venture back to Blender to render the height maps though.....if I can figure out how to render stuff created in MoI.
Thanks again,
602.7 In reply to 602.6
Hi All,
You guys will have some fun with this one... :-)
ZSurf will create a heightfield model from a bitmap in IGES format which can be imported into MoI
I found this article in Czech with some photos that you can reference.
http://tinyurl.com/yq5teh
http://tinyurl.com/yvpdtp
I could easily see making lithophanes with this process or incorporating the heightfield model into an
existing model. The edge curves can extruded into a solid model.
There's more info on ZSURFon the Rhino NG
The organic looking model is from a factal image that I mirrored, but, if you pre-processed the
image in GIMP or PhotoShop, I imagine you could smooth out the seam.
Faststone image Image Viewer has a editing thing that will make sort of a bump map out of an existing image.
http://www.faststone.org/
I didn't edit the BMP's I used for my experiment. You will have to convert some BMP's into 32 bit images in order for Zsurf to process them.
I just have one warning, don't try this during working hours or you'll never get anything done! :-)
-Jesse
http://mwt.net/~sjedging/ZSURF4.zip
EDITED: 9 May 2007 by JESSE
602.8 In reply to 602.7
Hi Jesse,
Here's some more info about ZSurf4 & using it with Rhino.
regards Colin
602.9 In reply to 602.8
I did check out Zsurf today, it is quit neat. Just works the opposite of what I need. I downloaded Blender again and will try creating in MoI and rendering the heightfield in Blender.
602.10 In reply to 602.8
Hi Colin,
I wasn't able to find the English version earlier today.
-Jesse
602.11 In reply to 602.7
Would it be possible to do Z-buffer rendering in MoI?
Or something like it?
I tried to re-position the light to make the shadows
more conducive to heightfield modeling.
I've been trying to use something from this page,
http://www.sjbaker.org/steve/omniv/love_your_z_buffer.html
but I'm a little out of my realm.
The image I got is the opposite of what I expected
and it lost shadowing at the highest points.
Be that as it may, I edited the image before processing
it in Zsurf, but you can see, the results are less than spectacular.
-Jesse
602.12 In reply to 602.11
Hi Jesse, it should be possible eventually but it will be a while. I will probably try to add some types of rendering capabilities for version 2.
Positioning the light won't really get you a height map image, because the standard light-based shading creates a color depending on the angle between the surface normal and the light.
For a height map you don't care about the angle, you care just about the position...
Rhino used to have a "ZBuffer" command that you could use to create a height map, so you could give that a try.
- MIchael
602.13
I found another posibility to render height maps last night http://www.anim8or.com/ and a halfway good tutorial http://www.anim8or.com/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html/tutorials/from_users/focal_blur/focalblur_1.html . Getting the 'Start' and 'End' settings set properly seems to be the only tricky part. The programs UI is MUCH better than Blender IMHO, so now I will venture to create in MoI and render the heightmap in anim8or.
602.14 In reply to 602.13
maybe you have a problem with the text editor :)
here the adresse
EDITED: 11 Apr 2008 by PILOU
602.15
Yes, I guess I was having problems, thanks for correcting it! I have made progress and can now create things in MoI and render a heightmap in Anim8tor. It is a workable solution but the rendering in Anim8tor leaves 'freckles' which I cleaned up with a slight gaussian blur. Now since I know how to make use of the beuatiful thigns I can create in MoI on my carving machine I'll get busy learning with MoI. Thanks again everyone for your help.
602.16 In reply to 602.15
Funny method before your carvermachine accept the import files !
http://support.vectric.com/cut3d-questions/item/can-you-use-carvewright-pattern-files
...again, provided you own the CarveWright STL Importer...
(There is also a CarveWright dxf importer...)
Show messages: All  1-3  4-17
