How do I save a screenshot of viewport and view it.
All  1  2-7
596.2 In reply to 596.1
Hi Rudy - in this case the 3D object data is what is stored in the clipboard. Only a 3D program like MoI will be able to interpret this data, clipbook viewer does not know how to process this kind of data itself.
The easiest way to capture your screenshot is to push the "Print Screen" key on your keyboard - this is normally somewhere in the upper-right corner of the keyboard. This will take a snapshot of the screen and put it into the clipboard as a bitmap image. Then you should be able to go to IrfanView and use Edit/Paste there to retrieve the bitmap image.
In a future version of MoI I will probably put both the 3D data as well as a bitmap screenshot into the clipboard, which would have made this work like you would expect. But I don't think I will have this for the 1.0 version.
596.3 In reply to 596.2
I got it,
thank you Michael.
596.4 In reply to 596.3
a free cool prog for any 2D drawing works
http://www.artweaver.de/
Painter + toshop functions !
EDITED: 7 May 2007 by PILOU
596.5 In reply to 596.1
Hi Rudy,
In IrfanView you're able to do a screen capture.
Select "Options">"Capture/Screenshot".
Hope this helps, Colin
Screen hunter free V5 :)
Very tricky! Auto named file etc...
http://wisdom-soft.com/products/screenhunter.htm
596.7 In reply to 596.6
For screen capture, I recommend these apps:
The best screen capture (IMO) - SnagIt: http://www.techsmith.com/snagit.asp
(You can't get too much better than the full Camtasia Studio but it's pricey. Adobe has Captivate but that's even more expensive...)
DebugMode's Wink if you want to delve into tutorial creation (for free): http://www.debugmode.com/wink/
Another good one for purchase UltraSnap Pro: http://www.mediachance.com/ultrasnap/index.html
(MediaChance has other good tools as well...)
I just love all of Iconico's tools (Calipers, Magnifier, ColorPic, etc.): http://www.iconico.com/
-Will
Show messages: All  1  2-7
