Detergent Bottle Problem
All  1-10  11-12
5823.11
Another question. I got that first Join to work fine and I notice that you use that command often enough but it doesn't seem to work for me later in the tutorial. Lines I have no issue joining, but I'm missing something with the surfaces. At the end of your tutorial you say to join everything. What are the limits/rules of joining objects/surfaces, i know I'm missing something there but not sure what.
Thanks again for all the help!
5823.12 In reply to 5823.11
Hi David, in order to join 2 surfaces they must have edges touching one another with no larger than a 0.005 unit gap between them. If there is too large of a space between them or if the edges are already joined to other things then either of those will prevent things from joining to one another.
If you have a case where join is not working as you had expected, please post the 3DM file with the things you are trying to join in it and then that would help to diagnose the specific problem that you are running into, it's much easier to tell you what is going wrong when looking at an actual model file rather than just a written description.
Show messages: All  1-10  11-12
