MoI doesn't want to open
All  1-5  6-10
5662.6 In reply to 5662.5
Hi ed, thanks for posting that. Your /tmp permissions look fine.
The entry in the log: "quartz-wm[2268]: can't open default display" looks like it could be the problem - I don't think that is supposed to happen on a normal run.
Have you possibly set the desktop screen resolution in any unusual way?
Can you try installing the regular XQuartz latest version from here: http://xquartz.macosforge.org/landing/ - does the regular XQuartz seem to launch ok for you? If it does, then try setting MoI to use the system XQuartz and see if that helps anything. You can reach the setting for that by right-clicking on the MoI .app and pick "Show package contents". Then inside there run Wineskin.app, and click the "Advanced" button and go to the "Options" tab, and then the settings to mess with are the bottom 2 checkboxes on that page - uncheck the "use wrapper's quartz-wm" one and check the "use system Xquartz" and see if that makes any difference.
5662.7
Thanks Michael, using XQuartz indeed helped!
5662.8
I'm trying to insert an 7086 × 4922 image but nothing is displayed on the viewport. I dont't know if its because I just have changed to XQuartz or because the resolution.
5662.9 In reply to 5662.7
Hi Ed, that's great news that you're up and running with the latest XQuartz - somehow the version built into MoI is running into some kind of bug on your system, I'm not sure what though. The XQuartz in Moi v2.52 is not far off from the current version...
It's most likely because of the high image resolution - an image that large is going to require 133MB all in one single chunk for the image data, and having so much as a single texture is probably too much for the video card to handle.
I'd recommend resizing it down to not more than around 2048 pixels in either dimension, that should likely help.
5662.10
Thank you!
Show messages: All  1-5  6-10
