Clamshell modeling help requested...
All  1  2-4
5606.2 In reply to 5606.1
I hope to understand what you want:
take a look at this part: points are not straight and,when extruded they produce a little curve difficult to fillet
i have moved these points in straight position with the rest of your shape
than extruded using tapered option obtaining a solid than filleted
then deleting a face and union all surfaces
sorry i have switched in Metric system so i did an improvisation (4 degrees tapered)
i think it works,hope you understand my example,take a look at the file attached
M
EDITED: 19 Dec 2021 by M-DYNAMICS
5606.3 In reply to 5606.2
Maybe select your curve
Press TAB
and write Rebuilb
you must obtain a dialog windows ;)
5606.4
Thanks to both responders. I see my mistake in the slightly messy geometry. I cleaned that up and things went as planned, after that. Consider this a lesson learned!
Thank-you,
Michael Cramblet
Packaging Design
Phone: 616-574-6271
Show messages: All  1  2-4
