how to blend this?
 1-8  9-22
5556.9 In reply to 5556.8
Hi Ed,
> I'm really surprised Merge is not a button on the UI. Even though a new button adds
> complexity to the UI, it seems to be a necessary function.
One problem is that I haven't figured out how to set it up so that there won't be confusion between "Join" and "Merge"... I still have some small amount of hope that I might be able to combine these functions together into a single command.
5556.10 In reply to 5556.9
Michael.
Join was the tool I was naturally drawn towards when I tried connecting some edges together, so integrating the two seems like a great idea to me, if it's possible.
Martin (2).
5556.11
That makes sense.
You can use the Merge command on an entire surface, which will link together all the separate segments that lie next to each other - but Merge can only be used when you have those kinds of features selected.
The same with Join and surface edges, also Join and not-edge curve elements.
So I could see Merge command via Join working as well.
Just cut the button in 2 parts ;)
5556.13 In reply to 5556.11
As using Join on edges currently creates a curve, it might make an issue that would need to be addressed, but It'd also make sense to reduce any possibility of confusion between the Merge command and the Boolean Merge tool.
Maybe a 'Create Curve or Edge?' option in the Join tool would work, once edges have been selected.
Martin (2).
5556.14 In reply to 5556.12
Frenchy - do you mean Separate the Join tool? :-)
Martin (2).
5556.15 In reply to 5556.14
<< do you mean Separate the Join tool? :-)
Just Idea :)
Something like this
You can click top or bottom following you want Merge or Join ;)
5556.16 In reply to 5556.15
Good one Pilou! ;-)
Then you could argue for a expandable sub-menu for the "Join" tool set.
5556.17 In reply to 5556.16
My thoughts exactly!
5556.18 In reply to 5556.17
Possible too! :)
5556.19 In reply to 5556.17
Ah..ha-ha-ha!!! Funny!
...now MoI will smite you. :-|
5556.20 In reply to 5556.19
Smite me... O mighty smiter!
5556.21 In reply to 5556.17
Hi Marco, Ha! that would be a pretty cool UI for it! ;)
5556.22
Never once thought of using 'merge'. Thanks for the heads-up!
Show messages:  1-8  9-22
