how to blend this?
 1-11  12-22
Just cut the button in 2 parts ;)
5556.13 In reply to 5556.11
As using Join on edges currently creates a curve, it might make an issue that would need to be addressed, but It'd also make sense to reduce any possibility of confusion between the Merge command and the Boolean Merge tool.
Maybe a 'Create Curve or Edge?' option in the Join tool would work, once edges have been selected.
Martin (2).
5556.14 In reply to 5556.12
Frenchy - do you mean Separate the Join tool? :-)
Martin (2).
5556.15 In reply to 5556.14
<< do you mean Separate the Join tool? :-)
Just Idea :)
Something like this
You can click top or bottom following you want Merge or Join ;)
5556.16 In reply to 5556.15
Good one Pilou! ;-)
Then you could argue for a expandable sub-menu for the "Join" tool set.
5556.17 In reply to 5556.16
My thoughts exactly!
5556.18 In reply to 5556.17
Possible too! :)
5556.19 In reply to 5556.17
Ah..ha-ha-ha!!! Funny!
...now MoI will smite you. :-|
5556.20 In reply to 5556.19
Smite me... O mighty smiter!
5556.21 In reply to 5556.17
Hi Marco, Ha! that would be a pretty cool UI for it! ;)
5556.22
Never once thought of using 'merge'. Thanks for the heads-up!
Show messages:  1-11  12-22
