Surface Area and Volume
All  1-8  9-12
Did a simple copy and paste from MoI, of an extruded polygon, into Alibre, as a bunch of 3d surfaces, including the face for which the acreage is needed,
as per Ralf-S. There is no need to stitch to solid in Alibre.
In Alibre, used the 3D Measurement tool to get square inch area of a face surface.
Just need to scale the MoI map trace to physical distance reality, before the paste, and convert the Alibre area to acres.
(Have not got arround to doing a MoI script to measure planar area of a polygon plane yet. Do not need such a script now. In my naivity, I think it is possible, just wondering about what order the sides of a closed polyline could be stored in, under different creation circumstances, and whether to extract the points by line segment, or by 2d polygon vertex?)
EDITED: 16 Nov 2012 by BEMFARMER
5549.10
yes, change the size of the object in a volume Desired, this will be great! It could allow the calculation of material and many other things, :)
-Kaël
I've put together a planar 3d polygon face area measuring script, but it still has bugs.
The vector/point math is a bit confusing. Just need to properly code the remaining 10% incorrectness. :-)
I've been resisting asking for help. (The math is fairly simple...)
For a nurbs face area, and or volume, the complex nurbs Gaussian quadrature integration, like the Berkeley link, is
beyond my current ability.
EDITED: 5 Dec 2012 by BEMFARMER
Here is the PolygonFaceArea Script, as a slightly tested draft.
It does not work on circles, nor nurbs curves, just planar faces, with straight line edges.
It does work for such faces in 3D space, with x, y, and z coordinates.
There is a lot of switching between points and vectors, which seemed to be necessary.
Portions of several existing scripts were used, including "bisector line", "angle", and "switch from faces to edges".
The "duplicate borders" script was used to switch from edges, to the line segments, to get the vertexes = start points.
Do edges have start and end points?
The main reference is Allen Van Gelder, "Efficient computation of polygon area and polyhedron volume," which is chapter 11 in the
book "Graphic Gems V." This chapter can be downloaded. It is not necessary to compute the surface normal.
Also looked at a JAVA program which used surface normals. Also looked at a Fast Polygon method, which uses projection and Newell Normals,
and is computationally more efficient.
The script only does one face at a time. It needs to be tested more.
The script should probably clean up the extra edge lines generated, and have sequential selections improved.
An early draft worked at the origin. Subsequent drafts refused to work, for a long time, without using vectors, and generated the area as 1.#QNB which
may indicate trying to display points as area values...
EDITED: 6 Dec 2012 by BEMFARMER
Show messages: All  1-8  9-12
