background image size
All  1-4  5-12
5548.5 In reply to 5548.4
Hi Michael - I guess I am not coming across very clear again.
I always start my projects as "No Unit System", so if I do need to be using a background image as a tracing template I then draw a box to the same dimensions as the image, so if the images is 800 x 600 the box is drawn to the same scale as the image. The box is then positioned as mid point or centre point to origin and the image is then loaded and placed using the snaps provided by the box geometry. Once placed the box becomes locked or hidden or just plane old deleted, but once drawing/tracing commences I am still using no units system and effectively speaking the scale becomes 1 pixel of the image = 1 no scale unit of MoI, hence me saying that I am using the pixel size as a unit size. Once all the drawing is done, you can scale to what unit of measurement you need or just plane change the unit of measurement to whatever you need, feet, inches, mm etc.
All of this works fine for me right up to the point of export when the OBJ files, no matter what the unit size is, are exported as huge mesh objects. Once the object gets imported into other rendering packages they come in as massive objects, but again this can be fixed in the export mesh options by using the scaling tool provided in the OBJ exporter. If on the other hand you are using rendering engine such as KeyShot that does not seem to have a world limit until any objects are imported in then you don't even need to worry about the scaling of the exported object
I hope I have made a little more sense this time with my rambling - All the best
Martin Spencer-Ford
5548.6 In reply to 5548.5
Hi Martin,
> <...> hence me saying that I am using the pixel size as a unit size.
Ok, but I'm not really aware of this being a common practice to base your entire model size upon the pixel size of the background images... And doing this is what is giving you the side effect of using a fairly large numbers for your objects causing the "huge objects" problem that you mention.
Instead of setting up your entire model as if it was all made of pixels, it tends to be better to instead assign some distance inside the bitmap like along one line in it to be a particular unit size, then you can use the Image align tool to pick the reference points on that bitmap line and then set that to a matching line in the model, there's a demo of that here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1982.9
5548.7 In reply to 5548.6
Nifty little trick that Mr. Gibson .... This will help a lot when it comes to vehicle modelling and creating 1:1 scale model. Thanks ;) appreciated!
Martin Spencer-Ford
5548.8
hi probably didn't explain myself too well.
I wanted the BG image to work as Modo. When i add an image it comes in at 100%. I would then draw a circle say 100mm dia. to match the 100 mm dia. flange on the image. At this point i would scale the image of the flange to match the circle i just drew. Now i am drawing at the correct unit size.
At this point i would need to add the other images in the other views, but instead of going thru the process again it would be good to know at what percentage i scaled the first image so i can simply set the remaining images to exactly the same scale. Then would just have to worry about getting the image into the correct location.
Hope this clearer . . .
matt
5548.9 In reply to 5548.8
Hi Mattj - Wonderful idea but I am not sure because i have not tried it yet, but by using the scaling trick showed by Michael, once you have that first image in place, as long as all the other images are the same scale, then you should be able to select the show in all views option in the image menu, then once you place and scale that first image in place, there will be visible lines in the other views that you can use as snap and reference points.
Does that help ?
Martin Spencer-Ford
5548.10
thanks martin s
i will try that.
matt j
5548.11 In reply to 5548.8
Hi matt,
So you mean you don't get to place it by "drawing" a rectangle for like you do in MoI? It just comes in at some fixed predefined 3D size?
MoI's background images do not work like that - instead of an image coming in at some fixed size, you tell MoI the size by drawing a rectangle. Since there is not some automatic predefined size used, there isn't anything in MoI for a percentage value to be based off of.
Just in general the "generate new object" philosophy in MoI is to allow you to draw the object directly where you want it when it is first created, so for example in MoI's sphere command it does not stick in a "default sphere" and then make you move and resize it in order to get the actual sphere you want, instead you get to draw the sphere where you want when it is first created, and so the background image mechanism is set up in that same way.
But check out these examples for how to snap images together in various ways, that may be useful for what you are asking about:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2501.14
http://moi3d.com/forum/index.php?webtag=MOI&msg=2501.15
http://moi3d.com/forum/index.php?webtag=MOI&msg=1982.6
5548.12
Ok I will try your method. Thanks for all the contributions, much appreciated as ever!
Matt
Show messages: All  1-4  5-12
