Finding Length of Curves?
 1-19  20-31
5496.20 In reply to 5496.17
> I have a tag for put pure HTML but seems it don't take all !
Well <code> </code> is not standard HTML, it's something that is specific to just this forum software which controls how the forum software will handle using what you typed whether as HTML control codes or "escaping" it so that it shows as text directly.
If you're using some kind of blogging/CMS type system for your web site it's possible they have some particular way of doing a similar thing.
5496.21 In reply to 5496.20
Well actually I guess there is a <code> tag in standard HTML as well, but it is additionally treated specially by the forum software as well to make sure the contents are "escaped" and not used as HTML tags...
5496.22 In reply to 5496.21
I believe that the solution for me is put a file to load ?
5496.24 In reply to 5496.22
Hi Pilou, if you are able to directly edit the HTML then you want to put this in as the HTML code for the problem part:
  &lt;div id=_crvdistlabel&gt;&lt;/div&gt;
But this will only work if you are actually directly editing the HTML - if the editor tries to be smart and substitute some stuff for you (by changing & to the "escaped" &amp;) it will then get messed up.
Maybe you should just put a link to a post on the forum or to Petr's page in for this particular one.
http://kyticka.webzdarma.cz/3d/moi/#CurveLengthBeingDrawn
I have made that ;)
Text in (utf-8) are the best for accents ?
http://moiscript.weebly.com/curvelengthbeingdrawn.html
5496.26 In reply to 5496.25
Yes utf-8 format is good for that.
5496.27 In reply to 5496.26
5496.28 In reply to 5496.27
Hi Pilou, yup that looks good now, I tested your one and it works fine now!
5496.29 In reply to 5496.28
Cool!
So now I must refind all scripts where there are the tag "HTML" :)
Not sure that I make that before the next week ! :)
5496.30
can the length of a selected curve be displayed on the properties panel for the next version of MoI?
5496.31 In reply to 5496.30
Hi ed, no unfortunately it can't very easily go on the properties panel because that information is shown on every mouse click and so it isn't feasible to put anything there that can possibly require a lot of calculation. Trying to put calculation-heavy stuff right there would result in weird freezes and pauses while you were selecting objects...
I do expect to have a kind of extended properties dialog that will be able to have controls on it for generating various kinds of information like this on it. But that won't be ready for the next immediate beta though.
Show messages:  1-19  20-31
