> Because if I must all change in my numerous pages...or just the ones with "HTML" inside ?
Probably only ones with HTML inside of the actual script itself.
> this one is good for you ?
> http://moiscript.weebly.com/curvelengthbeingdrawn.html
Hmm, actually still not right on your web page there because you only want to have < in your page's base HTML code which will then display in the browser as <
But it seems that whatever you're using for posting has already escaped any ampersands, if you do a "view source" of your page you'll see your HTML code ends up as: &lt; instead of <
Maybe whatever system you're using for editing your web site has some way to tell it to use only the plain text of what you put, like in the forum here putting stuff inside of <code> </code> will do.
