MoI v3 - crash debugging
All  1-8  9-13
5452.9 In reply to 5452.8
File version/date for moi_lib.dll for the Sep-1 v3 are exactly as you state: 09/01/2012 04:12 PM 5,273,088 moi_lib.dll - here's the screengrab of my v3 SEP 01 install directory, if that's of any further interest: https://www.dropbox.com/s/u5ccn9fmyojgfre/MoI%203.0%20beta%202012-09-01_cmd_screengrab.jpg
The only change I've made within the v3 install directory is adding the CustomDistance.js /.htm script (dated 6/13/2008) to the commands folder.
>when you check Task Manager, is moi.exe still running or not?
moi.exe is no longer present after any crashes.
>And just to confirm, if you only simply launch MoI and do nothing else at all (no loading of files, etc...), you get a crash after a while just having left the program totally undisturbed?
Correct. And for further clarification, it makes no difference whether other programs, (whether started automatically at system startup or manually) are running in the background or not. However, the average period between starting MoI and it crashing seems to have increased (from 5 - 10 mins to 10 - 20 mins) since I changed the video drivers and had a good clean out my installed programs; this might be coincidence.
BTW, it makes no difference if my AV is active or temporarily disabled.
I'll do a memory test tonight using Memtest86+ and let you know how it goes.
Any other ideas for stress testing?
Also, is there any point in seeing if MoI will 'crash-while-idle' in safe-mode? Perhaps this might eliminate or implicate the display driver? I noticed when I tried running MoI in safemode I received the error "Unable to create Direct3D9 device", identical, except for the (higher) display resolution, to the one when the latest video driver wouldn't install properly as shown here:
https://www.dropbox.com/s/ylxawznl7zzs410/moi_screen_dump_640_480.JPG
hamish
5452.10 In reply to 5452.9
Hi Hamish, well that's all pretty baffling.
The main thing that's particularly weird is that there haven't been a whole lot of changes in the display mechanism (other than the multi-threading which you already disabled) from v2 to v3, so I don't really understand why only recent v3 betas would show this problem for you...
Is there any possibility that your video card is overheating? If you don't have any method set up to measure that you might try using a monitoring app (here's one: http://www.cpuid.com/softwares/hwmonitor.html) to see if the temperatures are creeping up while the 3D graphics functions of your card are in use. Also if your machine is clogged up with dust that would be good to vacuum out and if it has gotten pushed up close to a wall maybe it needs more space to get better airflow through it.
But if those were the case I would really expect to see v2 behaving like that as well, I don't understand why you would only see this on v3.
5452.11 In reply to 5452.9
Hi Hamish, can you contact me through e-mail at moi@moi3d.com ? I'll prepare some test versions of some older v3 betas and send them to you and see if that can narrow it down to one specific change that then causes the problem.
5452.12 In reply to 5452.11
I'll be in contact be email.
Thanks for the link to CPUID Hardware Monitor. Very useful.
On the slightest chance this is of benefit to anyone else:
As expected, the Memtest86+ tests resulted in a pass with zero errors.
According to the CPUID HM, CPU temp was around 30 degC, while GPU temp was at 86 degC. (My Mobo has onboard graphics and only a CPU and PWR supply fans due to small case size.) Re dust, there is a little, but I did already vacuum out a LOT of dust a few months back as the entire PC kept repeatedly crashing. Since then I've had no system crashes - and MoI v2 is stable under the current (relatively hot GPU) conditions.
As an exercise, I just rigged up a 2.5 cu.m/min (88 cu.ft/min) fan to blow into the open case. GPU temp is now 38 deg C, while system and CPU are 25 and 21 degC respectively. Left idle, at the lower temps, MoI v3 continues to crash however.
- Hamish
EDITED: 7 Oct 2012 by HAIRYKIWI
5452.13
hi
I've found in the past, that once a CPU/GPU run to hot for 2 long, it's time to replace them... :(
Cheers, Steve
Show messages: All  1-8  9-13
