Array on a spline with some randomisation
 1-17  18-37  38-57  58-66
5416.58 In reply to 5416.57
Hi Mike, well does MoI run ok for you like if you click on the Line command can you draw a line?
If so then you're probably not really very messed up, you still have the original commands folder and you just have an additional extra one somewhere else that's not doing any harm other than not doing anything if you try to copy plug-ins there.
So if you're running ok you already have a commands folder where it is supposed to be, you can delete the additional one under drive_c/commands and leave the original one under drive_c/moi/commands .
If your main commands folder was completely missing you'd definitely notice big problems, almost nothing would work.
To get to the original commands folder, right-click on the .app and choose "Show package contents", then double click drive_c then double click moi then double click commands.
5416.59 In reply to 5416.58
Let me think about this. Your help is outstanding. I suppose this points out some pitfalls for users like me that aren't aees good at maneuvering some structure complexities.
It's seems difficult for me but I am getting through it because of your patience. Your personal customer service is notable to say the least!!
5416.60 In reply to 5416.59
No problem Mike, and yes I do want to make plug-in installation simpler in the future.
Do other regular commands like Line for example work ok for you right now?
If you're still stuck you can send me an e-mail and I'll arrange a time to do a remote-control screen sharing session with you so I can get your installation sorted out.
5416.61 In reply to 5416.60
Wow! I'll get back with you as soon as I can. Love your product!!
5416.62 In reply to 5416.61
I took the path of least resistance and I reinstalled MOI. Then I followed you directions as to installing the commands, including Randomize. I even set-up the CustomUI again.
I seemed to be ok and back running. As simple as this process probably was I struggled. Because I persevered I think I now have the process down. Because you were there to assist and teach me it helped me stay with it. Thanks again!
5416.63 In reply to 5416.62
No problem Mike, I'm glad you are all set up now!
Seems Undo not effective ?
5416.65 In reply to 5416.64
I've made a tuneup to fix that up, there is a new version here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5416.5
5416.66 In reply to 5416.65
Perfect now!
Show messages:  1-17  18-37  38-57  58-66
