Optimally Ordered Antipodally Symmetric Point Set Generator, also Non-Antipodal. For unit sphere. Import the point files
 1-12  13-22
5199.13 In reply to 5199.12
Hi Stefan is there some way that the text file is getting changed when you download it? Are you opening it in a text editor after downloading it or something similar to that?
Do you have any special downloader mechanism that you are using? I just used Safari to download the file to my desktop and it seemed to work fine for me over here.
5199.14 In reply to 5199.12
Hi Stefan, also is your system locale set to something that uses the comma character as the decimal point separator? Maybe there is some issue with that, although you did say that other text files worked ok for you, is that right?
5199.15 In reply to 5199.14
i downloaded the file also with Safari and have no other downloader used. About the system locale i'm not
quite sure, i changed terminal a while ago to ISO Latin 9 instead of UTF-8 for an older email client under
Terminal. But i switched it back now and it displays still the same in MoI. However i also renamed the
file with an .asc extension and loaded it in Meshlab and there it displays the point fine. The other both
files from Ben worked fine.
5199.16 In reply to 5199.15
I just checked and this is my locale settings:
5199.17 In reply to 5199.16
i switched my locale settings as a test to United States and now MoI displays Ben's 50points file properly.
I must admit i never had this problem before on my Mac.
5199.18 In reply to 5199.17
Hi Stefan, the locale can have an impact on how numbers are parsed with certain kinds of parsing functions.
Somewhere in there is a bug that numbers are being parsed with a locale-specific handler when it should not be.
Thank you for posting your settings and for testing with altered locale to narrow down the problem, that should let me reproduce it over here and investigate a fix.
5199.19 In reply to 5199.17
It is kind of weird that other files did work ok for you though. Anyway tomorrow I will investigate and try to see what's going on there.
5199.20 In reply to 5199.19
.Deleted irrelevant post.
EDITED: 22 Jun 2012 by BEMFARMER
5199.21 In reply to 5199.17
Hi Stefan, I've been investigating this import point file problem today and it seems to be a bug pretty deep in the scripting system involving conversion of string values to number values. It's also not unique to the Mac version, it happens on the Windows version too.
I'm working on a fix to the script engine itself for the next v3 release, but in the meantime here is an updated ImportPointFile plug-in which has a slight modification which will avoid triggering this particular bug, this version should work for you with your original locale settings, please let me know if it still does not.
5199.22 In reply to 5199.21
works fine now! Thank you very much for the quick fix, much appreciated!
Show messages:  1-12  13-22
