[wish] unlock objects for export
All  1-2  3-4
4932.3 In reply to 4932.1
And here's a different one that bundles the whole thing (unlock, export, then relock) into one command so it could be more convenient.
This one is installed as a command - unzip the attachment here and copy the 2 files into the \commands sub-folder inside of MoI's main installation folder. That will then make a new command available called UnlockExport , so put that as the command name for a shortcut key to trigger it. Note no ".js" on the end of this one, since it's a command and not an inline script which is slightly different.
4932.4 In reply to 4932.3
Thanks a lot!
What you see is what you believe - so don't. (from an Amiga500 demo)
Show messages: All  1-2  3-4
