Anyone wish to develop a custom script?
 1-15  16-35  36-55  56-75  76-95  96-115  …  216-223
4801.56 In reply to 4801.55
Regarding through points option, Blue curve and Blue points,
versus control points option, Red curve, and Red points.
Created two AirFoil curves, with two scripts differing by the following two lines, (using Styles for colors):
Blue points and Blue (interpret)curves are created with var factory = moi.command.createFactory( 'interpcurve' );
Red points and Red (curve)curves are created with var factory = moi.command.createFactory( 'curve' );
Note that the Red control points are the same AirFoil points (which would be) generated by the Fortran code, and also,
that these Red points are the Nurb control points for the Red curve.
Note that the Blue (interpret)curves pass through the Red control points.
The Blue control points I interpret to be Nurbs control points, which are NOT the Airfoil points which would be generated by the Fortran code.
Note that creating only the Blue (interpret)curves, that the Airfoil points are not shown, however by generating the Blue (interpret)curves, and
ALSO by using the (second) point factory "for loop", (via a third version of the interpcurve script, indexing the second "for loup" from zero to 28,)
to create ALL of the airfoil Points, that the airfoil Points show up, without using the "var factory = moi.command.createFactory( 'curve' );" code.
EDITED: 28 Dec 2011 by BEMFARMER
I have realized that trying to get MoI to access an array element that does not exist, causes an error.
Suggestions to Anthony, (or myself):
1. Do not hardcode the number of elements (27) in the arrays, in the Airfoil Points Do (or for) loup. ?
(Instead use the javascript array length.....)
2. Test to see if the number of elements in the AFXTAB and AFYTAB are the same. ? (With warning alert)
3. Place the Extra (radius) points in separate arrays similar to AFXTAB and AFYTAB. ? (same # of "X" and "Y" types.)
I will change the control points, as per your reminder above.
(Should be possible to have multiple airfoil cross sections, with nested loup......)
4801.58 In reply to 4801.57
Hi bemfarmer,
A lot of that is way over my head. But the reason for the control points aspect of the airfoil curve generation is because of the leading and trailing edge circles. The NACA data points do not agree with the radius they specify for the le and te. If you were to strictly follow everything they specify in the document, you would end up with a lumpy airfoil. The picture you attached with the red and blue curves do not have the leading and trailing edge circles in there. So that may be why you aren't sure why I'm deviating from the data points at this step.
The hard part is going to be coding all that from your aspect. I don't know how you script MoI to generate a model, or if it can be done. So I can only speak about how I am doing it manually. I don't know if that translates to the way it would be coded. But it should become pretty obvious to you when you start to try and generate the whole airfoil, that you will have to use the control points option for the airfoil data points.
To get the whole airfoil curve that you need for the sweep, I do the following:
1) make circles at the leading and trailing edge, using the naca defined radii
2) make a line from the last naca point defined near the le and te to points tangent to the circles
3) make points at the intersection of the lines and circles
4) delete the lines and circles
5) use the new points as the start and end of a spline that runs through the naca defined points, using the control points option
6) mirror that spline
7) make arcs at the le and te
8) select all four curves and join them
Now you have a smooth airfoil that closely follows the naca document. You can sweep it using the le and te rails. The 1/4 chord rail is for reference. You can create the hub cutout with it, measure the radius, and apply loads later on with a different program if desired.
I hope that helps some.
Anthony
4801.59 In reply to 4801.58
Thanks Anthony.
Looked again at your 16 pictures of your process.
So the key is to find out the y and z coordinates of Tangent point T
I never before heard of Thale's theorem, but it provides another way to locate Tangent point T.
A high school student could probably canculate the formula for point T, given points P[1], P[2], and O. :-)
Not sure exactly which tools in MoI script to use...
http://en.wikipedia.org/wiki/Thales%27_theorem
http://en.wikipedia.org/wiki/Tangent_lines_to_circles
4801.60
Aren't you making an assumption that the leading and trailing edges are circular for any distance? I read the NACA specs to say that they are not constant radius at any point of the profile. All that is given is the instantaneous curvature radius at the leading edge point and the trailing edge point. I read one article that suggested using a tilted ellipse at the leading edge replacing the first points of the equation.
4801.61 In reply to 4801.60
Hi bemfarmer,
I never heard of that theorem either. You seem to be on the right track though. SteveMacc, I have the radius going through the end points of the airfoil, so that the chord works out. I have never tried fitting an ellipse to the data. The trailing edge works out as is. You can use the NACA points and the ter they define with no issue. The ler and the data are what do not agree. In order to keep the chord, using the radius they define, I curve fit the data points. If you know of another way, please demonstrate. I'd be interested in looking at it.
Time for a script update.
This script functions pretty good.
There are still likely errors and mistakes.
Extra points have been moved to the end of the AFXTAB and AFYTAB arrays.
There is an AirFoil curve version, and an interpcurve version.
There is a narrow menu for MoI2, and a wider menu for MoI3Beta.
The leading edges and trailing edges have not been converted to radii, but this can be
easily done in MoI.
Using either the curve version, or the interpcurve version, I think there will be a (tiny) flat or bump spot, where the
radius joins with the airfoil "spline." (Seems to me the control points should be on the surface of the blade, via interpcurve...),
but for artistic work, they are both very close...
EDITED: 10 Aug 2013 by BEMFARMER
4801.63 In reply to 4801.62
i tried out the updated scripts. its looking good. the reason your curve is a little lumpy is because the very first and last points that you are using are for the creation of the leading and trailing edge circles. so there are a total of four points there for reference. the rest of the points are the ones you want to use for curve fitting the airfoil shape.
i have a question about installing your script. how do you get the narrow script to work. i copied all the files into the commands folder, but when it starts it is the wider version being used. likewise, how do you go about stalling the curve version as opposed to the other version of the javascript.
4801.64 In reply to 4801.63
Tried out the script. I was able to fillet the leading edge nicely. although that causes me to loose the original intent of the airfoils curves.
I wonder if it would be better to get the end radius values with a fillet "after" the solid has been generated? Just poking my 2 cents in...
4801.65 In reply to 4801.63
Hi Anthony,
Need to rename either the narrow .htm menu name to match the the javascript .js name, (with different extensions of course.),
or vice versa. (With matching shortcut key of course.)
Variations of scripts and menu's, with modified, but matching names, can have different shortcut keys.
I have a few ideas of how to automate the top and bottom arcs, maybe using part of trim....
The bisector line script looks interesting. There is a wealth of information in Michaels scripts, which I'm trying to underestand...
4801.66 In reply to 4801.65
For example use rename...
PropDesignGeoCurve.js (Curve version)
PropDesignGeoCurve.htm (narrow version)
(with shortcut key command PropDesignGeoCurve)
Creating radius arcs at leading edge & trailing edge using control points
Leading edge radius arc:
1. Calculate all AirFoil control points, as points only.
2. Using pt_ex1 as center, and pt_af1 as radius, form upper half of
semicircular arc_le.
3. Calculate pt_thales1, or locate it using midpoint of line segment from
pt_ex1 to pt_af2.
4. Using pt_thales1 as center, and pt_ex1 as radius, create upper
semicircular arc_thales1.
5. Find intersection of arc_le, and arc_thales1, which is point (pt_tan1).
6. Create new arc_le, using pt_ex1 as center, and pt_af1 as radius start, and
pt_tan1 as radius end.
7. Push arc_le into AirFoilfactories array.
8. Similarly, create arc_te at trailing edge, pt_thales2, and pt_tan2.
9. Starting at pt_tan1, create control points curve factory, using pt_af2...
pt_af24, and pt_tan2. and push into AirFoilfactories array.
10. Push arc_te int AirFoilfactories array.
11. Commit AirFoilfactories array.
12. Create Rails.
Done.
Also tried out a leading edge radius, using the upper NURBS control point ,of the interpcurve "spline",
in order to create the tangent point. (Don't know if this would be workable in practice.)
I think the leading edge should be a euler spiral curve. (spiro). ??
4801.69 In reply to 4801.68
I tried renaming them after I posted that message and it worked out. But glad to know that is what I was supposed to do. The first two pics you posted in your last message look good. I couldn't quite tell about the third pic. It really seems like you know what you are doing now though. Thanks again for all your hard work. I look forward to the next version. I will be away from the computer for most of the day.
Anthony
P.S. I played with some of the blade generation options this time and it seems like it is working. Didn't do a definitive check. But I tried counterclockwise rotation with forward sweep, and elliptical chord distribution, and a different chord, and it all recalculated fine. This is going to be a real time saver. Would it be possible to show the points on the rail lines. Also having the rail lines, rail points, in their own layer. And the airfoil curve(s) and airfoil points in their own layer.
4801.70 In reply to 4801.69
Scenebrowser Objects or Styles = "layers", and Hide/unHide. http://moi3d.com/forum/index.php?webtag=MOI&msg=4783.2
It would be possible to show the control points for the Rails, using 3 or so pointfactory script lines... (maybe in the
same loop that creates the Rails (?).
The script output should be compared with the fortran output to see if they match, to find errors.
What about using Fillet for the edges?
The top Rail has some portion of the curve in -Y area which seems wrong?
4801.71 In reply to 4801.70
I think trying to fillet the rails won't work as its a chicken and egg thing. You need something to fillet in order to get the right geo. You can't get the right geo with the rest of the geometry defined. You really have to complete the airfoil curve first. I do use a lot of filleting in the models, just not at that step. This is the reason I'm looking for a good solid, otherwise the filleting doesn't work out. Or the boolean ops. To make the hub and so forth.
I plan on checking everything in detail once you get further along.
4801.72 In reply to 4801.71
You cant have those curves continue up to a point instead of breaking away into a radius?
4801.73 In reply to 4801.72
I've assumed that the slope at the leading edge point would be zero, which the "control points curve" or "through points interpcurve" do not seem to accomplish.
Played around with creating multiple points on the leading edge radius, with array curve, and using them for "control points curve" or "through points interpcurve".
Blue = through points using the extra points.
Black = current method, control points starting at tangent point.
Red = control points starting with the extra radius array points.
Need to LEARN how to calculate MidPoint of a line, given the two endpoints, which should be easy.
There is already a MoI script, "DoArcCenter". Mainly need to LEARN how to substitute existing points, for PointPicker
There already exists a MoI script, "DoIntersect", just need LEARN how to substitute the two arcs for ObjectPicker list, somehow, which a good programmer could do easily. :-)
4801.74 In reply to 4801.73
Hi Brian, to create your own object list from scratch call:
var mylist = moi.geometryDatabase.createObjectList();
You can then add an object to it by using the .addObject() method, like:
mylist.addObject( somecurve );
4801.75
hi burrman,
the naca points stop short of the leading edge radius. this is the problem really. if they extended out enough then you probably could have some sort of shape that you could then fillet after the fact. but you can't have a smooth continuous spline without a few extra steps. i have a screencast showing how i do it. you and michael actually helped me determine that process awhile back. it works great. i have no problem at all doing it manually. i just thought it would be nice for new users of prop_design and moi to have a script. its asking them to learn an aweful lot without it. you have to learn prop_design and moi and then figure out how to model the blade in moi otherwise. this way its a lot easier on a new user.
anthony
Show messages:  1-15  16-35  36-55  56-75  76-95  96-115  116-135  …  216-223
