surface through the points at different heights
4735.1
Hi you can create a surface through the points at different heights?
4735.2 In reply to 4735.1
Hi Tony, do you mean like a kind of terrain surface?
One method is to draw several curves that are slices of the desired surface and then use Construct > Loft to build a surface through them.
Also see this previous discussion for a variety of other ideas and techniques you could use:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3551.1
4735.3 In reply to 4735.2
I have to model a ground
I have several points at different heights and I would like to create a surface through these points
4735.4 In reply to 4735.3
Hi Tony, so for making a surface that goes through a specific point you would probably use the "Draw curve > Freeform > Through points" command to make a curve that passes through that point and then use that curve along with some others to build the surface.
Set them up as several sections, like the example in the image attached to this post:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2321.31
In the future I would like to make a command that would fit a surface through particular points, but currently MoI does not have a command like that and instead is focused on making a surface through curves. So in order to make a surface that goes through a point make a curve that goes through that point and then make a surface from that curve.
4735.5 In reply to 4735.4
Thanks Michael :))
4735.6 In reply to 4735.5
Care to post the file?
4735.7 In reply to 4735.6
This is a sample file
My intent was to create a surface by selecting all the points simultaneously
4735.8 In reply to 4735.7
Hi Tony,
See if this gives you any results.. I opened your file and ran the "ConnectPoints" script on it.. Then I ran rebuild by points with a value that smoothed the curve a bit (The more points, the more it is like the polyline). Then I lofted the curves for this surface.
4735.9 In reply to 4735.8
Thanks BurrMan :)
4735.10 In reply to 4735.9
Obviously not as good as having the surface from points command, but maybe a make due for now..
