Rope molding
All  1-8  9-11
4611.9 In reply to 4611.8
pretty cool indeed.
4611.10
Many polys on export! :( probably i would make a texture for the small details
4611.11 In reply to 4611.10
Hi Max,
A texture is definitely going to be a lot more efficient. But it's often difficult for a texture to look 100% the same as real geometry especially if you are going to be zoomed in at all. If it's going to only be a tiny thing on the screen then a texture instead can work well though.
There are techniques you can use on the rendering side to start with high res geometry like this, then create a normal map from that which then is applied to a low res mesh. That usually does a good job but for that method you need to start with an initial detailed high res mesh.
If you're just doing a still rendering and not making game assets, it's not really so much of a concern to have a lot of polygons on export these days - renderers are much more able to handle high poly counts than say 20 years ago.
Show messages: All  1-8  9-11
