making wooden bangles
All  1-2  3-6
4572.3 In reply to 4572.1
Hi Mike, thanks for sending me an example image through e-mail - I wanted to post it here also in case any others had some feedback for these kinds of shapes:
These should be pretty straightforward to do in MoI - it looks like one process you could use for the construction would be to draw a curve outline and then extrude it into a solid using the Construct > Extrude command.
That would look something like this - create a curve in the Front view something like this:
In the 3D view it would look like this:
Select that curve and run Construct > Extrude to make it into a solid:
You can now cut this solid with some other curves to make some more details, for example draw a curve in the Top view like this:
Then select the solid and use the Construct > Boolean > Difference command to cut the solid with that curve, dividing it into pieces like this:
Delete the piece that you don't want and you'll have this final result:
But probably before trying this, I would recommend going through the video tutorials here:
http://moi3d.com/2.0/docs/tutorials.htm
They're not too long and they go step by step through the process of drawing curves and constructing a few different objects, they'll give you a good general overview of how things work. After you watch those the process for the above model will be easier to follow along.
Hope this helps!
4572.4 In reply to 4572.3
Thanks Michael,
That helps immensley as I am visual tactal learner , ultimately I would like to duplicate my carvings with a larger machine some day
I have some old pic's on my site if you care to look www.msbryant.com.
Thankyou very much as it really clears things up for me....
sincerely
MSB
4572.5 In reply to 4572.4
Your carving website does not display carvings. Is it broken?
4572.6 In reply to 4572.5
I tried it and it seemed to be ok other than my work is about 2007 vintage.
www.msbryant.com
Mike
Show messages: All  1-2  3-6
