 1-8  …  649-668  669-688  689-708  709-728  729-748  …  2689-2698
4446.689 In reply to 4446.685
The SPH videos are quite impressive indeed. They remind me of a free Blender add-on called Molecular Add-on:
Regards,
Metin
visualization • illustration • animation • 3D design — metinseven.nl
4446.690 In reply to 4446.689
Yes particles are magical things!
and of course ;)
Free BricsCad Shape https://www.bricsys.com/en-intl/shape/
Funny one but you must make a little training! :)
Direct modeling is cool and Fillet, Chamfer, Boolean some strong!
Moi to Shape is easy by SKP format inbetweener
Render of course SimLab Composer lite (free)
PS If you export as DAE to SKetchUP, seems there is a bug even both programs are in unity meter!
You must scale * 1000 in Shape before the exportation!
else you will have some faces no filled!
EDITED: 2 May 2019 by PILOU
For Demoparties fan! :)
4446.695 In reply to 4446.694
Ah, the good old demo scene. My friends and I created a number of demos for the Commodore Amiga back in the late 1980s and early 1990s.
@ Marco : We can now directly transform a "big" format OBJ directly in .vox for MagicaVoxel! ;)
with the Zarbuz plugin : https://github.com/Zarbuz/FileToVox/releases
from Squarries http://www.fractal-recursions.com/files/mech0025.html
With the old free Chaoscope http://www.chaoscope.org
4446.697 In reply to 4446.696
Wow!!!
Very cool stuff!
I just pinned this post :)
Funny to think that is a little part of the strange attractor above! :)
With free BricsCad Shape! (function Quick draw) :)
Draw 2-3 volumes Make a Snapshot - dupplicate / rotate / resize the few volumes on a PNG transparent background Image and drag & drop the result on my own little tricky free prog https://editor.p5js.org/Pilou/full/y1GHaBqyT
Put it inside MagicaVoxel + File2Vox by Zarbuz et voilà! :)
EDITED: 10 May 2019 by PILOU
4446.700 In reply to 4446.699
The last one is AMAZING!
Test with an image of Moi3D objects :)
EDITED: 11 May 2019 by PILOU
Rocket 3F as Polygonal modeling is always pleasant to use!
inside MagicaVoxel for exploring some infinite worlds! ...
As you can run Moi onAndroïd tablett :) see https://moi3d.com/forum/index.php?webtag=MOI&msg=9374.1
2 cool programs in direct Tablett (so speedy max)
And this last one (different than the direct viewer - https://play.google.com/store/apps/details?id=com.autodesk.fusion tested working like a charm)
Not yet tested the following...on Tablett or in local computer
If you gothere you will see how was resolved my problem of Moi on Android Tablett! ;)
https://moi3d.com/forum/index.php?webtag=MOI&msg=9374.13
This is made (5 seconds) with these free https://www.escapemotions.com/experiments.php by Peter Blaskovic
EDITED: 24 May 2019 by PILOU
Then imported with File2 vox by Zarbuz inside MagicaVoxel
Infinite exploration!
And of course you can export OBJ for the Free TwinMotion!  :)
4446.706 In reply to 4446.705
Wonderful!
With the free Verve!
Show messages:  1-8  …  629-648  649-668  669-688  689-708  709-728  729-748  749-768  …  2689-2698
