issues
All  1  2-4
4386.2 In reply to 4386.1
Hi Andras - could you please explain a little more about what exact offset you're trying to do?
I loaded your file and tried offsetting all the individual surfaces by 1 unit and they all seemed to generate an offset.
Then I tried joining them together into a solid (using Edit > Join command) and that also seemed to offset.
One thing that may be causing a problem is that there seems to be an extra degenerate surface in your model - I noticed when I did an area select that the selection indicator said "7 Surfaces" were selected, but there are only 6 big surfaces that seem to be present. If you select the 6 main surfaces by clicking on them:
And then delete those, you'll see the 7th surface is this little fragment that looks like a line here:
So probably that little degenerate surface (it may be a surface that has all of its area trimmed away from it so it's more like a line instead of a surface) is causing some problems?
4386.3 In reply to 4386.1
Hi Andras, also I see now that trying to join only the 6 big pieces together does not give a solid - doing that and then selecting naked edges led me to this small irregularity in 2 corners of the shape:
There seems to be a tiny micro edge in those areas with a length of only 0.003 units - that's almost certainly what is interfering with filleting.
It looks like you may be able to fix that by selecting the 6 main pieces and using the Merge command:
http://moi3d.com/2.0/docs/moi_command_reference10.htm#merge
That should merge the micro edge with its much longer neighbor so it's all one single long edge.
I've attached a tuned up 3DM file where I did that - this one should probably behave better for you now.
4386.4 In reply to 4386.3
Hi Michael!
Thanks for your answer. my model looks messy , sorry next time I should check before send I gonna check it again, I set 0.6 value, anyway. thanks again.
Show messages: All  1  2-4
