Internet Explorer Script Error
432.1
I recently upgraded to IE7, When I tried to activate the Image button it appears this confirm box.
An error has occured on this page:
Line: 95
Char: 5
Error: 'moi' is undefined
Code: 0
URL: moi://commands/image.htm
If I press 'yes' nothing happens.
Do I have to change the setting of Internet Explorer in order to enable this tool?
P.S.: don't press the link above:)
432.2 In reply to 432.1
Hi Syziph
It seems like there is something that can go wrong with an IE7 upgrade that causes this problem as a side effect. It doesn't happen often, you are the 3rd or 4th person to run into it.
It can be solved by doing a reset of IE7 settings.
To do this, go to IE7 Tools menu, Internet Options, Advanced Tab and click on the Reset button near the bottom of the page. Here is a blog post that shows this: http://blogs.msdn.com/ie/archive/2006/06/12/628499.aspx
MoI should work fine once you do the reset, please let me know if you have any problems after that.
432.3
Thanks Michael,
Resetting IE to defaults worked!
I'm sorry for the late reply and for repeating the question (I couldn't find similar topic, or haven't used appropriate keywords).
